I am having some issues opening/importing the NTM88+KW38 Schematics, Gerber and BOM files gerber files into Altium. When importing into .cam file everything works fine in the first place and the programm shows an appropriate illustration of the file. After assigning the layers and exporting to a .pcb the rotated pads are bigger then before which can be seen in the second picture.
I probably has something to do with my Altium and NC tool settings.
Is it possible to receive information which software was used to design the board or information on how to use the gerber files to manufacturer the pcb?
Thanks for your help.
Hello Luca,
As far as I know the board was designed in Cadence Allegro. Unfortunately I am not very familiar with importing it into Altium, perhaps someone else will be able to help.
Tomas
