FXOS8700CQR1 calibration fails every second time
shop
Dear Community,
I am using the FXOS8700CQR1 sucessfully on Atmel controller.
But every second time, the calibration fails:
First time I can calibrate it.
xmag average= -474
ymag average=-569
zmag average=-626
when I start the second time, calibration fails with
xmag average= -82
ymag average=-88
zmag average=-374
I have reviewed and compared code with examples here:
FXOS8700CQ - Bare metal example project
Accelerometer and magnetometer FXOS8700CQ example code for MQX4.1.1
Problem I still cannot get it. The problem is reproducible every second time.
I call both calibration from the attached library.
      FXO.SetAccelOffset();
and
FXO.CalibrateMagn();
thank you and best regads,
Alain
Labels (2)
shop
After deeply investigation, I found out, that prior to a new calibration the offset values must be reset to 0 for all axes. Includes Magnetometer and Accelerometer.
Now it is working very good!
rubensjunior
FXOS8700CQR1 calibration fails every second time‌,
Dear Alain Fuchs,
It is correct, and can viewed in https://www.nxp.com/docs/en/data-sheet/FXOS8700CQ.pdf .
Best Regards.
