FXOS8700 SPI Woes
3,458件の閲覧回数
warren1
I am attempting to use the FXOS8700 in SPI mode due to the faster read / write times associated with SPI (higher possible bus speed). I have set up the SPI bus to run with the following parameters which are consistent with the FXOS8700 data sheet:
CLK: 1 MHz
Order: MSB First
CPOL: Rising/Falling
CPHA: Sample/Setup
I have verified the above settings on an oscilloscope so I know that the bus is set up correctly.
In order to get the FXOS into SPI mode, I tri-state the MISO pin before toggling the reset pin, and waiting the required time for the auto detection circuit to put the device into SPI mode. I then attempt to read the WHO_AM_I register and get the value 0x1e instead of 0xc7 which is what I would expect. Below is the code I am using to reset the device and read the WHO_AM_I register:
#define FXOS_MISO   26
#define FXOS_CS     11
#define FXOS_RST    3
void FXOSSPI()
    // Tri-state MISO
    pinMode( FXOS_MISO, TRI_STATE );
    delay( 10 );
    // Reset the FXOS
    digitalWrite( FXOS_RST, HIGH );
    digitalWrite( FXOS_RST, LOW );
    delay( 1 );
    // Set up the bus
    SPISettings _settings = SPISettings( 1000000, MSBFIRST, SPI_MODE0 );
    SPI1.beginTransaction( _settings );
    // Read WHO_AM_I
    uint8_t tx[3] = { ( 0x0D >> 1 ) & 0xFF, ( 0x0D << 7 ) & 0xFF , 0xFF };
    digitalWrite( FXOS_CS, LOW );
    for( uint8_t i = 0; i < 3; i++)
        buff[i] = SPI1.transfer( tx[i] );
    digitalWrite( FXOS_CS, HIGH );
    SPI1.end();
After I run that function I check the contents of buff using a break point and ICD, the contents of buff are:
buff[0] = 0xFF
buff[1] = 0xFF
buff[2] = 0x1E
Obviously, bytes 0, and 1 are DC because we are writing the R/W bits and the register address, but byte 2 should be 0xC7.  Not really sure what is going on here, I have looked at this many times under a scope, verified SPI register settings via ICD, slowed down the clock rate, etc. Still get the same results. Anybody else getting this problem? The only thing I can think of now is that my FXOS is damaged or something.
タグ(1)
3,163件の閲覧回数
TomasVaverka
Hi Warren,
I think I found where the problem is. You are not addressing the WHO_AM_I register (0x0D) correctly.
As shown in the datasheet:
Byte 0: R/W, ADDR[6], ADDR[5], ADDR[4], ADDR[3], ADDR[2], ADDR[1], ADDR[0]
Byte 1: ADDR[7], X, X, X, X, X, X, X
In your case tx[0] = ( 0x0D >> 1 ) & 0xFF while the correct way is tx[0] = 0x0D & 0x7F. Similarly tx[1] = ( 0x0D << 7 ) & 0xFF while the correct form is tx[1] = 0x0D & 0x80.
Here is my complete read a register function:
* Read a byte from the FXOS8700CQ
* Byte 0: 0,ADDR[6],ADDR[5],ADDR[4],ADDR[3],ADDR[2],ADDR[1],ADDR[0]
* Byte 1: ADDR[7],0,0,0,0,0,0,0
* Byte 2: 0,0,0,0,0,0,0,0
unsigned char FXOS8700CQ_ReadRegister(unsigned char RegisterAddress)
 unsigned char i;
 CS_Enable;
 while (!(SPI0_S & SPI_S_SPTEF_MASK));
 SPI0_D = 0x7F & RegisterAddress;
 while (!(SPI0_S & SPI_S_SPRF_MASK));
 i = SPI0_D;
 SPI0_D = 0x80 & RegisterAddress;
 i = SPI0_D;
 SPI0_D = 0x00; // Dummy byte
 i = SPI0_D;
CS_Disable;
 return i;
I hope it helps.
Tomas
3 返答(返信)
3,163件の閲覧回数
warren1
Hi Tomas,
I can't believe I missed that! Just goes to show the value of having a fresh set of eyes on your code. Thank you, everything is working as planned now.
- Warren
3,163件の閲覧回数
TomasVaverka
You are very welcome, Warren.
Very glad to hear it is working now!
Tomas
3,164件の閲覧回数
TomasVaverka
Hi Warren,
 unsigned char i;
 CS_Enable;
 i = SPI0_D;
 i = SPI0_D;
 i = SPI0_D;
CS_Disable;
 return i;
I hope it helps.
Tomas
%3CLINGO-SUB%20id%3D%22lingo-sub-821249%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFXOS8700%20SPI%E3%81%AE%E8%8B%A6%E6%82%A9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-821249%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3ESPI%20%E3%81%AB%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%2F%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E6%99%82%E9%96%93%E3%81%8C%E9%80%9F%E3%81%84%20(%E3%83%90%E3%82%B9%E9%80%9F%E5%BA%A6%E3%81%8C%E9%80%9F%E3%81%84)%20%E3%81%9F%E3%82%81%E3%80%81FXOS8700%20%E3%82%92%20SPI%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82FXOS8700%20%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%81%A8%E4%B8%80%E8%87%B4%E3%81%99%E3%82%8B%E6%AC%A1%E3%81%AE%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%A7%20SPI%20%E3%83%90%E3%82%B9%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%3A%201MHz%3C%2FP%3E%3CP%3E%E9%A0%86%E5%BA%8F%3A%20MSB%E3%83%95%E3%82%A1%E3%83%BC%E3%82%B9%E3%83%88%3C%2FP%3E%3CP%3ECPOL%3A%20%E4%B8%8A%E6%98%87%2F%E4%B8%8B%E9%99%8D%3C%2FP%3E%3CP%3ECPHA%3A%20%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%2F%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%B8%8A%E8%A8%98%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%92%E3%82%AA%E3%82%B7%E3%83%AD%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%97%E3%81%A7%E6%A4%9C%E8%A8%BC%E3%81%97%E3%81%9F%E3%81%AE%E3%81%A7%E3%80%81%E3%83%90%E3%82%B9%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EFXOS%20%E3%82%92%20SPI%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%20%E3%83%94%E3%83%B3%E3%82%92%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%82%8B%E5%89%8D%E3%81%AB%20MISO%20%E3%83%94%E3%83%B3%E3%82%92%E3%83%88%E3%83%A9%E3%82%A4%E3%82%B9%E3%83%86%E3%83%BC%E3%83%88%E3%81%AB%E3%81%97%E3%81%A6%E3%80%81%E8%87%AA%E5%8B%95%E6%A4%9C%E5%87%BA%E5%9B%9E%E8%B7%AF%E3%81%8C%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%20SPI%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AA%E6%99%82%E9%96%93%E3%82%92%E5%BE%85%E6%A9%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E6%AC%A1%E3%81%AB%E3%80%81WHO_AM_I%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8D%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E4%BA%88%E6%83%B3%E3%81%A9%E3%81%8A%E3%82%8A%200xc7%20%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%200x1e%20%E3%81%A8%E3%81%84%E3%81%86%E5%80%A4%E3%81%8C%E8%BF%94%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E4%BB%A5%E4%B8%8B%E3%81%AF%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%97%E3%80%81WHO_AM_I%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CDIV%3E%3CDIV%3E%23%E5%AE%9A%E7%BE%A9%20FXOS_MISO%2026%3CBR%20%2F%3E%20%23%E5%AE%9A%E7%BE%A9%20FXOS_CS%2011%3CBR%20%2F%3E%20%23%E5%AE%9A%E7%BE%A9%20FXOS_RST%203%3CBR%20%2F%3E%20FXOSSPI()%20%E3%82%92%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%7B%3CBR%20%2F%3E%20%2F%2F%20%E3%83%88%E3%83%A9%E3%82%A4%E3%82%B9%E3%83%86%E3%83%BC%E3%83%88MISO%3CBR%20%2F%3E%E3%83%94%E3%83%B3%E3%83%A2%E3%83%BC%E3%83%89(%20FXOS_MISO%2C%20TRI_STATE%20)%3B%3CBR%20%2F%3E%E9%81%85%E5%BB%B6(10)%3B%3C%2FDIV%3E%3CDIV%3E%20%3C%2FDIV%3E%3CDIV%3E%2F%2F%20FXOS%E3%82%92%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%99%E3%82%8B%3CBR%20%2F%3E%E3%83%87%E3%82%B8%E3%82%BF%E3%83%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF(FXOS_RST%E3%80%81HIGH)%3B%3CBR%20%2F%3E%E3%83%87%E3%82%B8%E3%82%BF%E3%83%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF(FXOS_RST%E3%80%81LOW)%3B%3CBR%20%2F%3E%E9%81%85%E5%BB%B6(1)%3B%3C%2FDIV%3E%3CDIV%3E%20%3C%2FDIV%3E%3CDIV%3E%2F%2F%20%E3%83%90%E3%82%B9%E3%82%92%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%99%E3%82%8B%3CBR%20%2F%3ESPISettings%20_settings%20%3D%20SPISettings(%201000000%2C%20MSBFIRST%2C%20SPI_MODE0%20)%3B%3CBR%20%2F%3E%20SPI1.beginTransaction(_%E8%A8%AD%E5%AE%9A%20%EF%BC%89%3B%3C%2FDIV%3E%3CDIV%3E%2F%2F%20WHO_AM_I%20%E3%82%92%E8%AA%AD%E3%82%80%3CBR%20%2F%3Euint8_t%20tx%5B3%5D%20%3D%20%7B%20(%200x0D%20%26gt%3B%26gt%3B%201%20)%20%26amp%3B%200xFF%2C%20(%200x0D%20%26lt%3B%26lt%3B%207%20)%20%26amp%3B%200xFF%20%2C%200xFF%20%7D%3B%3CBR%20%2F%3E%E3%83%87%E3%82%B8%E3%82%BF%E3%83%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF(FXOS_CS%2C%20LOW)%3B%3C%2FDIV%3E%3CDIV%3Efor(%20uint8_t%20i%20%3D%200%3B%20i%20%26lt%3B%203%3B%20i%2B%2B)%3CBR%20%2F%3E%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%5Bi%5D%20%3D%20SPI1.%E8%BB%A2%E9%80%81(tx%5Bi%5D%20)%3B%3C%2FDIV%3E%3CDIV%3E%E3%83%87%E3%82%B8%E3%82%BF%E3%83%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF(FXOS_CS%2C%20HIGH)%3B%3CBR%20%2F%3E%20SPI1.end()%3B%3CBR%20%2F%3E%7D%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%AE%E9%96%A2%E6%95%B0%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81%E3%83%96%E3%83%AC%E3%83%BC%E3%82%AF%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%A8%20ICD%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20buff%20%E3%81%AE%E5%86%85%E5%AE%B9%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82buff%20%E3%81%AE%E5%86%85%E5%AE%B9%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%3E%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%5B0%5D%20%3D%200xFF%3C%2FP%3E%3CP%3E%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%5B1%5D%20%3D%200xFF%3C%2FP%3E%3CP%3E%E3%83%90%E3%83%95%5B2%5D%20%3D%200x1E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%98%8E%E3%82%89%E3%81%8B%E3%81%AB%E3%80%81R%2FW%20%E3%83%93%E3%83%83%E3%83%88%E3%81%A8%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%93%E3%81%A7%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%83%90%E3%82%A4%E3%83%88%200%20%E3%81%A8%201%20%E3%81%AF%20DC%20%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%83%90%E3%82%A4%E3%83%88%202%20%E3%81%AF%200xC7%20%E3%81%A7%E3%81%82%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%93%E3%81%A7%E4%BD%95%E3%81%8C%E8%B5%B7%E3%81%93%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%8B%E3%82%88%E3%81%8F%E5%88%86%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%97%E3%81%A7%E4%BD%95%E5%BA%A6%E3%82%82%E8%AA%BF%E3%81%B9%E3%81%9F%E3%82%8A%E3%80%81ICD%20%E7%B5%8C%E7%94%B1%E3%81%A7%20SPI%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E8%A8%AD%E5%AE%9A%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%9F%E3%82%8A%E3%80%81%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20%E3%83%AC%E3%83%BC%E3%83%88%E3%82%92%E9%81%85%E3%81%8F%E3%81%97%E3%81%9F%E3%82%8A%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%9D%E3%82%8C%E3%81%A7%E3%82%82%E5%90%8C%E3%81%98%E7%B5%90%E6%9E%9C%E3%81%8C%E5%BE%97%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E4%BB%96%E3%81%AB%E3%82%82%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E9%81%AD%E9%81%87%E3%81%97%E3%81%9F%E4%BA%BA%E3%81%AF%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%E4%BB%8A%E8%80%83%E3%81%88%E3%82%89%E3%82%8C%E3%82%8B%E3%81%AE%E3%81%AF%E3%80%81FXOS%20%E3%81%8C%E7%A0%B4%E6%90%8D%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E4%BD%95%E3%81%8B%E3%81%A8%E3%81%84%E3%81%86%E3%81%93%E3%81%A8%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-821249%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E7%A3%81%E6%B0%97%E3%82%BB%E3%83%B3%E3%82%B5%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-821252%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FXOS8700%20SPI%20Woes%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-821252%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%A9%E3%81%86%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%A6%E3%80%81%E3%82%A6%E3%82%A9%E3%83%BC%E3%83%AC%E3%83%B3%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BB%8A%E3%81%AF%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E8%81%9E%E3%81%84%E3%81%A6%E3%81%A8%E3%81%A6%E3%82%82%E5%AC%89%E3%81%97%E3%81%84%E3%81%A7%E3%81%99!%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%88%E3%83%BC%E3%83%9E%E3%82%B9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-821251%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FXOS8700%20SPI%20Woes%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-821251%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%83%88%E3%83%BC%E3%83%9E%E3%82%B9%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%9D%E3%82%8C%E3%82%92%E8%A6%8B%E9%80%83%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%AA%E3%82%93%E3%81%A6%E4%BF%A1%E3%81%98%E3%82%89%E3%82%8C%E3%81%AA%E3%81%84%EF%BC%81%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E6%96%B0%E9%AE%AE%E3%81%AA%E7%9B%AE%E3%81%A7%E8%A6%8B%E3%82%8B%E4%BE%A1%E5%80%A4%E3%82%92%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E8%A8%80%E3%81%88%E3%81%BE%E3%81%99%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E7%8F%BE%E5%9C%A8%E3%81%AF%E3%81%99%E3%81%B9%E3%81%A6%E8%A8%88%E7%94%BB%E9%80%9A%E3%82%8A%E3%81%AB%E9%80%B2%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E-%20%E3%82%A6%E3%82%A9%E3%83%BC%E3%83%AC%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-821250%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FXOS8700%20SPI%20Woes%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-821250%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%82%A6%E3%82%A9%E3%83%BC%E3%83%AC%E3%83%B3%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%A9%E3%81%93%E3%81%AB%E3%81%82%E3%82%8B%E3%81%8B%E3%81%8C%E5%88%86%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82WHO_AM_I%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%20(0x0D)%20%E3%82%92%E6%AD%A3%E3%81%97%E3%81%8F%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E6%8C%87%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%81%AB%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%3A%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%83%90%E3%82%A4%E3%83%880%3A%20R%2FW%E3%80%81ADDR%5B6%5D%E3%80%81ADDR%5B5%5D%E3%80%81ADDR%5B4%5D%E3%80%81ADDR%5B3%5D%E3%80%81ADDR%5B2%5D%E3%80%81ADDR%5B1%5D%E3%80%81ADDR%5B0%5D%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E3%83%90%E3%82%A4%E3%83%881%3A%20ADDR%5B7%5D%E3%80%81X%E3%80%81X%E3%80%81X%E3%80%81X%E3%80%81X%E3%80%81X%E3%80%81X%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81tx%5B0%5D%20%3D%20(%200x0D%20%26gt%3B%26gt%3B%201%20)%20%26amp%3B%200xFF%20%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E6%AD%A3%E3%81%97%E3%81%84%E6%96%B9%E6%B3%95%E3%81%AF%3CSTRONG%3Etx%5B0%5D%20%3D%200x0D%20%26amp%3B%200x7F%3C%2FSTRONG%3E%E3%81%A7%E3%81%99%E3%80%82%E5%90%8C%E6%A7%98%E3%81%ABtx%5B1%5D%20%3D%20(%200x0D%20%26lt%3B%26lt%3B%207%20)%20%26amp%3B%200xFF%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E6%AD%A3%E3%81%97%E3%81%84%E5%BD%A2%E5%BC%8F%E3%81%AF%3CSTRONG%3Etx%5B1%5D%20%3D%200x0D%20%26amp%3B%200x80%3C%2FSTRONG%3E%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%AE%8C%E5%85%A8%E3%81%AA%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E9%96%A2%E6%95%B0%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CPRE%20class%3D%22language-c%20line-numbers%22%3E%3CCODE%20translate%3D%22no%22%3E%3CSPAN%20class%3D%22comment%20token%22%3E%2F******************************************************************************%0A*%20Read%20a%20byte%20from%20the%20FXOS8700CQ%0A*%20%0A*%20Byte%200%3A%200%2CADDR%5B6%5D%2CADDR%5B5%5D%2CADDR%5B4%5D%2CADDR%5B3%5D%2CADDR%5B2%5D%2CADDR%5B1%5D%2CADDR%5B0%5D%0A*%20Byte%201%3A%20ADDR%5B7%5D%2C0%2C0%2C0%2C0%2C0%2C0%2C0%0A*%20Byte%202%3A%200%2C0%2C0%2C0%2C0%2C0%2C0%2C0%0A******************************************************************************%2F%3C%2FSPAN%3E%20%0A%3CSPAN%20class%3D%22keyword%20token%22%3Eunsigned%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22keyword%20token%22%3Echar%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22token%20function%22%3EFXOS8700CQ_ReadRegister%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3E%3CSPAN%20class%3D%22keyword%20token%22%3Eunsigned%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22keyword%20token%22%3Echar%3C%2FSPAN%3E%20RegisterAddress%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%0A%3CSPAN%20class%3D%22punctuation%20token%22%3E%7B%3C%2FSPAN%3E%0A%20%3CSPAN%20class%3D%22keyword%20token%22%3Eunsigned%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22keyword%20token%22%3Echar%3C%2FSPAN%3E%20i%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20%0A%20CS_Enable%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20%0A%20%3CSPAN%20class%3D%22keyword%20token%22%3Ewhile%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E!%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3ESPI0_S%20%3CSPAN%20class%3D%22operator%20token%22%3E%26amp%3B%3C%2FSPAN%3E%20SPI_S_SPTEF_MASK%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20SPI0_D%20%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E0x7F%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22operator%20token%22%3E%26amp%3B%3C%2FSPAN%3E%20RegisterAddress%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20%3CSPAN%20class%3D%22keyword%20token%22%3Ewhile%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E!%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3ESPI0_S%20%3CSPAN%20class%3D%22operator%20token%22%3E%26amp%3B%3C%2FSPAN%3E%20SPI_S_SPRF_MASK%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20i%20%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%20SPI0_D%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%20%0A%20%0A%20%3CSPAN%20class%3D%22keyword%20token%22%3Ewhile%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E!%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3ESPI0_S%20%3CSPAN%20class%3D%22operator%20token%22%3E%26amp%3B%3C%2FSPAN%3E%20SPI_S_SPTEF_MASK%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20SPI0_D%20%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E0x80%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22operator%20token%22%3E%26amp%3B%3C%2FSPAN%3E%20RegisterAddress%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20%3CSPAN%20class%3D%22keyword%20token%22%3Ewhile%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E!%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3ESPI0_S%20%3CSPAN%20class%3D%22operator%20token%22%3E%26amp%3B%3C%2FSPAN%3E%20SPI_S_SPRF_MASK%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20i%20%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%20SPI0_D%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20%0A%20%3CSPAN%20class%3D%22keyword%20token%22%3Ewhile%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E!%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3ESPI0_S%20%3CSPAN%20class%3D%22operator%20token%22%3E%26amp%3B%3C%2FSPAN%3E%20SPI_S_SPTEF_MASK%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20SPI0_D%20%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22number%20token%22%3E0x00%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22comment%20token%22%3E%2F%2F%20Dummy%20byte%3C%2FSPAN%3E%0A%20%3CSPAN%20class%3D%22keyword%20token%22%3Ewhile%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3E%3CSPAN%20class%3D%22operator%20token%22%3E!%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E(%3C%2FSPAN%3ESPI0_S%20%3CSPAN%20class%3D%22operator%20token%22%3E%26amp%3B%3C%2FSPAN%3E%20SPI_S_SPRF_MASK%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E)%3C%2FSPAN%3E%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20i%20%3CSPAN%20class%3D%22operator%20token%22%3E%3D%3C%2FSPAN%3E%20SPI0_D%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0ACS_Disable%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%20%0A%20%3CSPAN%20class%3D%22keyword%20token%22%3Ereturn%3C%2FSPAN%3E%20i%3CSPAN%20class%3D%22punctuation%20token%22%3E%3B%3C%2FSPAN%3E%0A%3CSPAN%20class%3D%22punctuation%20token%22%3E%7D%3C%2FSPAN%3E%3CSPAN%20class%3D%22line-numbers-rows%22%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3CSPAN%3E%E2%80%8D%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E3%81%8A%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A6%E3%82%8C%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%88%E3%83%BC%E3%83%9E%E3%82%B9%3C%2FP%3E%3C%2FLINGO-BODY%3E
