FXLS8964AF
FXLS8964AF
950 次查看
DivyaN
Please let us know what are the IIH (Input Current High) and IIL (Input Current Low) [ i.e the leakage current value when the pin is set to an input and is driven high or low] for the GPIOs and I2C interfaces as we do not find it in datasheet.
Thank you,
Divya.N
940 次查看
guoweisun
There is no any current value spec under VIH/VIL test result, only VOH/VOL spec will identify such test current value.
930 次查看
DivyaN
Hi    Guoweisun,
Thank you for your immediate reply.
We need this value for load analysis. Could you please let us know " What is the leakage current of a GPIO pins when the pins are set as an input pin and is driven high or low.
Divya.N
