The data sheet shows pins 3 and 13 as reserved (Connect to GND if unused). What happens if they are left open?
Solved! Go to Solution.
Hi Sean Havanas,
Pins 3 and 13 are used for factory trim and tests, if you left open these pins, it would probably not affect the performance of the device, however, I would strongly recommend to connect these pins to ground as mentioned in the datasheet.
Jose Reyes
Hi Sean Havanas,
Jose Reyes
