[FXAS21002C] what is the voltage for 0g ?
1,394件の閲覧回数
jonathan_kest
Hi All,
As subject, I am not able find VzeroG value in the datasheet. Can anyone help ?
Jonathan
1,298件の閲覧回数
TomasVaverka
Hi Jonathan,
I suppose that you mean the Zero-rate Offset which is actually specified in the data sheet. Note that it can slightly change after mounting the sensor onto a PCB and this is also reflected in the data sheet:
Tomas
PS: If this answer helps to solve your question, please mark it as "Correct" or “Helpful”. Thank you.
