We are using MMA8452 in our current product. Now we have a requirement to replace this part with a Autograde acclerometer.
Can we use MMA8452 in automotive application. Else please suggest a similar autograde part.
regards
Vinod sharma
Hi Vinod Sharma,
MMA8452 does not have an automotive certification however it can be used for some kind of automotive applications.
If you need an automotive grade certificate accelerometer I recommend you take a look at the different options in our current portfolio which are typically 1 or 2 axis accelerometers.
Jose
