Aging of MMA7361L
Aging of MMA7361L
uchidaJ
I would like to obtain the tilt angle using only the Z axis of MMA7361L. After the offset is calibrated at the assembly factory, if the end user uses it for 5 years without recalibrating it, what is the maximum change in tilt angle error?
onyourlight
MMA7361L  is eol
uchidaJ
Thank you for letting me know.
I'm sorry if my initial explanation was insufficient.
I posted on the forum with the intention of using parts I already own.
diazmarin09
Hello uchidaJ,
I hope all is great with you. Thank you for using the NXP communities.
It is difficult to know. There are a number of proponents when it comes to offset errors such as trim errors, mechanical stresses due to package and mounting, shifts due to temperature, and of course, aging.
Therefore, I do recommend to perform the calibration procedure periodically.
Please note that the MMA7361L is an obsolete device. Please let me know if you need further information for a replacement device.
I hope this information helps.
David
uchidaJ
Thanks, David.
I understand now that you need to perform the calibration procedure periodically.
Have a nice day.
