Accelerometer Axis Misalignment Compensation
5,148件の閲覧回数
PartOfTheSoluti
Does anyone know about three Axis Misalignment Compensation please?
How do you do it and does anyone have a little C/C++ to help or even VB that I could convert.
Many thanks
4 返答(返信)
4,307件の閲覧回数
PJH
Here's code I used.  Make sure that you have the Z-axis oriented so that it is vertical or experiencing 1G since the calibration works best this way.
void CMMA7455::CalibrateSensor()
    #define AVG_READS 64
    int err;
    m_I2C.ModuleWriteByte(GSENSOR,MCTL_REGISTER,MCTL_MODE0+MCTL_GLVL0);
    int x,y,z;
    long xAvg,yAvg,zAvg;
    xAvg=yAvg=zAvg=0;
    int lastXOffset=0;
    int lastYOffset=0;
    int lastZOffset=0;
    SetXAxisOffset(lastXOffset);  TRACE(_T("Last X Offset= %i\n"),lastXOffset);
    SetYAxisOffset(lastYOffset);  TRACE(_T("Last Y Offset= %i\n"),lastYOffset);
    SetZAxisOffset(lastZOffset);  TRACE(_T("Last Z Offset= %i\n"),lastZOffset);
    int loop=0;
    do
        xAvg=yAvg=zAvg=0;
        // Read the axes multiple times and average;
        for (int i=0; i<AVG_READS;i++)
            signed int data;
            err=ReadXAxis(&data);xAvg+=data;
            err=ReadYAxis(&data);yAvg+=data;
            err=ReadZAxis(&data);zAvg+=data;
        x=int(xAvg>>6);
        y=int(yAvg>>6);
        z=int(zAvg>>6);
        // Calculate the offset.
        lastXOffset=lastXOffset+(x*-2);
        lastYOffset=lastYOffset+(y*-2);
        lastZOffset=lastZOffset+((64-z)*2);
        //Set the offset.
        // Remeasure the values
        xAvg=yAvg=zAvg=0;
        for (int i=0; i<=AVG_READS;i++)
            signed int data;
        x=int(xAvg>>6);
        y=int(yAvg>>6);
        z=int(zAvg>>6);
        loop++;
    while( ((abs(x)>2) ||(abs(y)>2)||(abs(z-64)>2))&& (loop<10) ) ;
I'll leave the other functions as an exercise for the reader. I assume you can already read and write registers on the device.
4,307件の閲覧回数
PartOfTheSoluti
I understand the code but why are you doing it?
Many thanks
4,307件の閲覧回数
PJH
Because like all mechanical devices there are tolerances and variations. If you start up the device and read the values you will usually see that there is some measured deflection on x and y and also that z is greater than or equal to 1g.  Assuming you are using this in a stationary position on earth then all three axes should add up to give a 1g vector. If you arrange the device so that the z-axis is perpendicular to the earths surface, you should see 1g on that axis.
See App note,.AN3745
http://www.freescale.com/files/sensors/doc/app_note/AN3745.pdf
Peter
4,307件の閲覧回数
PartOfTheSoluti
Hello Peter and many thanks for the post.
Mmmm interesting way of doing this offset and scaling. I get the min & max values then use linear interpolation.
However the problem I am trying to find a solution to is compensating for axis alignment errors.
Have found this but math a bit heaving going for me.
http://www.summitinstruments.com/knowledge_center/pdf/TN413.pdf
%3CLINGO-SUB%20id%3D%22lingo-sub-211589%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%8A%A0%E9%80%9F%E5%BA%A6%E3%82%BB%E3%83%B3%E3%82%B5%E8%BB%B8%E3%81%9A%E3%82%8C%E8%A3%9C%E6%AD%A3%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-211589%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CBR%20%2F%3E%3CP%3E3%20%E8%BB%B8%E3%81%AE%E3%83%9F%E3%82%B9%E3%82%A2%E3%83%A9%E3%82%A4%E3%83%A1%E3%83%B3%E3%83%88%E8%A3%9C%E6%AD%A3%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E7%9F%A5%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E4%BA%BA%E3%81%AF%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%81%84%E3%81%84%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%E3%80%82C%2FC%2B%2B%20%E3%82%92%E5%B0%91%E3%81%97%E7%9F%A5%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E4%BA%BA%E3%82%84%E3%80%81%E5%A4%89%E6%8F%9B%E3%81%A7%E3%81%8D%E3%82%8B%20VB%20%E3%82%92%E7%9F%A5%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E4%BA%BA%E3%81%AF%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%A9%E3%81%86%E3%82%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-211593%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Accelerometer%20Axis%20Misalignment%20Compensation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-211593%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%83%94%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%95%E3%82%93%E3%80%82%E6%8A%95%E7%A8%BF%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%86%E3%83%BC%E3%82%93%E3%80%81%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%E3%81%A8%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AA%E3%83%B3%E3%82%B0%E3%82%92%E8%A1%8C%E3%81%86%E8%88%88%E5%91%B3%E6%B7%B1%E3%81%84%E6%96%B9%E6%B3%95%E3%81%A7%E3%81%99%E3%81%AD%E3%80%82%E6%9C%80%E5%B0%8F%E5%80%A4%E3%81%A8%E6%9C%80%E5%A4%A7%E5%80%A4%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%A6%E7%B7%9A%E5%BD%A2%E8%A3%9C%E9%96%93%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E7%A7%81%E3%81%8C%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%95%8F%E9%A1%8C%E3%81%AF%E3%80%81%E8%BB%B8%E3%81%AE%E4%BD%8D%E7%BD%AE%E5%90%88%E3%82%8F%E3%81%9B%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%92%E8%A3%9C%E6%AD%A3%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%93%E3%82%8C%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E6%95%B0%E5%AD%A6%E3%81%8C%E3%81%A1%E3%82%87%E3%81%A3%E3%81%A8%E9%9B%A3%E3%81%97%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fwww.summitinstruments.com%2Fknowledge_center%2Fpdf%2FTN413.pdf%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.summitinstruments.com%2Fknowledge_center%2Fpdf%2FTN413.pdf%3C%2FA%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-211592%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Accelerometer%20Axis%20Misalignment%20Compensation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-211592%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E6%A9%9F%E6%A2%B0%E8%A3%85%E7%BD%AE%E3%81%A8%E5%90%8C%E6%A7%98%E3%81%AB%E3%80%81%E8%A8%B1%E5%AE%B9%E5%B7%AE%E3%81%A8%E5%A4%89%E5%8B%95%E3%81%8C%E5%AD%98%E5%9C%A8%E3%81%99%E3%82%8B%E3%81%8B%E3%82%89%E3%81%A7%E3%81%99%E3%80%82%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E5%80%A4%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%E3%81%A8%E3%80%81%E9%80%9A%E5%B8%B8%E3%80%81x%20%E3%81%A8%20y%20%E3%81%AB%E4%BD%95%E3%82%89%E3%81%8B%E3%81%AE%E6%B8%AC%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%9F%E5%81%8F%E5%90%91%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81z%20%E3%81%8C%201g%20%E4%BB%A5%E4%B8%8A%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%82%92%E5%9C%B0%E7%90%83%E4%B8%8A%E3%81%AE%E9%9D%99%E6%AD%A2%E3%81%97%E3%81%9F%E4%BD%8D%E7%BD%AE%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E4%BB%AE%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%A8%E3%80%813%20%E3%81%A4%E3%81%AE%E8%BB%B8%E3%81%99%E3%81%B9%E3%81%A6%E3%82%92%E5%90%88%E8%A8%88%E3%81%99%E3%82%8B%E3%81%A8%201g%20%E3%83%99%E3%82%AF%E3%83%88%E3%83%AB%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82Z%20%E8%BB%B8%E3%81%8C%E5%9C%B0%E7%90%83%E3%81%AE%E8%A1%A8%E9%9D%A2%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6%E5%9E%82%E7%9B%B4%E3%81%AB%E3%81%AA%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E9%85%8D%E7%BD%AE%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%81%9D%E3%81%AE%E8%BB%B8%E3%81%AB%201g%20%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%8E%E3%83%BC%E3%83%88AN3745%E3%82%92%E5%8F%82%E7%85%A7%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fwww.freescale.com%2Ffiles%2Fsensors%2Fdoc%2Fapp_note%2FAN3745.pdf%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.freescale.com%2Ffiles%2Fsensors%2Fdoc%2Fapp_note%2FAN3745.pdf%3C%2FA%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%83%94%E3%83%BC%E3%82%BF%E3%83%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-211591%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Accelerometer%20Axis%20Misalignment%20Compensation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-211591%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E7%90%86%E8%A7%A3%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%AA%E3%81%9C%E3%81%9D%E3%82%8C%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%81%A9%E3%81%86%E3%82%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-211590%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Accelerometer%20Axis%20Misalignment%20Compensation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-211590%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%A7%81%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AF%E3%81%93%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%99%E3%82%8B%E3%81%A8%E6%9C%80%E9%81%A9%E3%81%AB%E6%A9%9F%E8%83%BD%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81Z%20%E8%BB%B8%E3%81%8C%E5%9E%82%E7%9B%B4%E3%81%AB%E3%81%AA%E3%82%8B%E3%81%8B%201G%20%E3%82%92%E7%B5%8C%E9%A8%93%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E5%90%91%E3%81%91%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3Evoid%20CMMA7455%3A%3ACalibrateSensor()%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20%23AVG_READS%2064%20%E3%82%92%E5%AE%9A%E7%BE%A9%E3%81%99%E3%82%8B%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%95%B4%E6%95%B0%E3%82%A8%E3%83%A9%E3%83%BC%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%20m_I2C.ModuleWriteByte(GSENSOR%E3%80%81MCTL_REGISTER%E3%80%81MCTL_MODE0%2BMCTL_GLVL0)%3B%3CBR%20%2F%3E%E6%95%B4%E6%95%B0%20x%2Cy%2Cz%3B%3CBR%20%2F%3E%E9%95%B7%E3%81%84%20xAvg%E3%80%81yAvg%E3%80%81zAvg%3B%3CBR%20%2F%3E%20x%E5%B9%B3%E5%9D%87%3Dy%E5%B9%B3%E5%9D%87%3Dz%E5%B9%B3%E5%9D%87%3D0%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%9C%80%E5%BE%8C%E3%81%AEX%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%E3%82%920%E3%81%A8%E3%81%99%E3%82%8B%3CBR%20%2F%3E%E6%9C%80%E5%BE%8C%E3%81%AEY%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%E3%82%920%E3%81%A8%E3%81%99%E3%82%8B%3CBR%20%2F%3E%E6%9C%80%E5%BE%8C%E3%81%AEZ%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%E3%82%920%E3%81%A8%E3%81%99%E3%82%8B%3CBR%20%2F%3E%3CBR%20%2F%3ESetXAxisOffset(lastXOffset)%3B%20TRACE(_T(%22%E6%9C%80%E5%BE%8C%E3%81%AEX%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%3D%20%25i%5Cn%22)%2ClastXOffset)%3B%3CBR%20%2F%3E%20SetYAxisOffset(lastYOffset)%3B%20TRACE(_T(%22%E6%9C%80%E5%BE%8C%E3%81%AEY%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%3D%20%25i%5Cn%22)%2ClastYOffset)%3B%3CBR%20%2F%3E%20SetZAxisOffset(lastZOffset)%3B%20TRACE(_T(%22%E6%9C%80%E5%BE%8C%E3%81%AEZ%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%3D%20%25i%5Cn%22)%2ClastZOffset)%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%95%B4%E6%95%B0%E3%83%AB%E3%83%BC%E3%83%97%3D0%3B%3CBR%20%2F%3E%E3%81%99%E3%82%8B%3CBR%20%2F%3E%7B%3CBR%20%2F%3E%20x%E5%B9%B3%E5%9D%87%3Dy%E5%B9%B3%E5%9D%87%3Dz%E5%B9%B3%E5%9D%87%3D0%3B%3CBR%20%2F%3E%20%2F%2F%20%E8%BB%B8%E3%82%92%E8%A4%87%E6%95%B0%E5%9B%9E%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%80%81%E5%B9%B3%E5%9D%87%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20(int%20i%3D0%3B%20i%3CAVG_READS%3E%3C%2FAVG_READS%3E%7B%3CBR%20%2F%3E%E7%AC%A6%E5%8F%B7%E4%BB%98%E3%81%8D%E6%95%B4%E6%95%B0%E3%83%87%E3%83%BC%E3%82%BF%3B%3CBR%20%2F%3E%20err%3DReadXAxis(%26amp%3Bdata)%3BxAvg%2B%3D%E3%83%87%E3%83%BC%E3%82%BF%3B%3CBR%20%2F%3E%20err%3DReadYAxis(%26amp%3Bdata)%3ByAvg%2B%3Ddata%3B%3CBR%20%2F%3E%20err%3DReadZAxis(%26amp%3Bdata)%3BzAvg%2B%3D%E3%83%87%E3%83%BC%E3%82%BF%3B%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%20x%20%3D%20int(x%E5%B9%B3%E5%9D%87%26gt%3B%26gt%3B6)%3B%3CBR%20%2F%3E%20y%20%3D%20int(y%E5%B9%B3%E5%9D%87%26gt%3B%26gt%3B6)%3B%3CBR%20%2F%3E%20z%3Dint(z%E5%B9%B3%E5%9D%87%26gt%3B%26gt%3B6)%3B%3CBR%20%2F%3E%20%2F%2F%20%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%E3%82%92%E8%A8%88%E7%AE%97%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3ElastXOffset%3DlastXOffset%2B(x*-2)%3B%3CBR%20%2F%3E%E6%9C%80%E5%BE%8C%E3%81%AEY%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%3D%E6%9C%80%E5%BE%8C%E3%81%AEY%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%2B(y*-2)%3B%3CBR%20%2F%3E%20lastZOffset%3DlastZOffset%2B((64-z)*2)%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%20%2F%2F%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3ESetXAxisOffset(lastXOffset)%3B%20TRACE(_T(%22%E6%9C%80%E5%BE%8C%E3%81%AEX%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%3D%20%25i%5Cn%22)%2ClastXOffset)%3B%3CBR%20%2F%3E%20SetYAxisOffset(lastYOffset)%3B%20TRACE(_T(%22%E6%9C%80%E5%BE%8C%E3%81%AEY%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%3D%20%25i%5Cn%22)%2ClastYOffset)%3B%3CBR%20%2F%3E%20SetZAxisOffset(lastZOffset)%3B%20TRACE(_T(%22%E6%9C%80%E5%BE%8C%E3%81%AEZ%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%3D%20%25i%5Cn%22)%2ClastZOffset)%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%20%2F%2F%20%E5%80%A4%E3%82%92%E5%86%8D%E6%B8%AC%E5%AE%9A%E3%81%99%E3%82%8B%3CBR%20%2F%3Ex%E5%B9%B3%E5%9D%87%3Dy%E5%B9%B3%E5%9D%87%3Dz%E5%B9%B3%E5%9D%87%3D0%3B%3CBR%20%2F%3E%20(int%20i%3D0%3B%20i%26lt%3B%3DAVG_READS%3B%20i%2B%2B)%20%E3%81%AE%E5%A0%B4%E5%90%88%3CBR%20%2F%3E%7B%3CBR%20%2F%3E%E7%AC%A6%E5%8F%B7%E4%BB%98%E3%81%8D%E6%95%B4%E6%95%B0%E3%83%87%E3%83%BC%E3%82%BF%3B%3CBR%20%2F%3E%20err%3DReadXAxis(%26amp%3Bdata)%3BxAvg%2B%3D%E3%83%87%E3%83%BC%E3%82%BF%3B%3CBR%20%2F%3E%20err%3DReadYAxis(%26amp%3Bdata)%3ByAvg%2B%3Ddata%3B%3CBR%20%2F%3E%20err%3DReadZAxis(%26amp%3Bdata)%3BzAvg%2B%3D%E3%83%87%E3%83%BC%E3%82%BF%3B%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%20x%20%3D%20int(x%E5%B9%B3%E5%9D%87%26gt%3B%26gt%3B6)%3B%3CBR%20%2F%3E%20y%20%3D%20int(y%E5%B9%B3%E5%9D%87%26gt%3B%26gt%3B6)%3B%3CBR%20%2F%3E%20z%3Dint(z%E5%B9%B3%E5%9D%87%26gt%3B%26gt%3B6)%3B%3CBR%20%2F%3E%E3%83%AB%E3%83%BC%E3%83%97%2B%2B%3B%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%20while(%20((abs(x)%26gt%3B2)%20%7C%7C(abs(y)%26gt%3B2)%7C%7C(abs(z-64)%26gt%3B2))%26amp%3B%26amp%3B%20(%E3%83%AB%E3%83%BC%E3%83%97%26lt%3B10)%20)%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%20%7D%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E4%BB%96%E3%81%AE%E9%96%A2%E6%95%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E8%AA%AD%E8%80%85%E3%81%AE%E7%B7%B4%E7%BF%92%E5%95%8F%E9%A1%8C%E3%81%A8%E3%81%97%E3%81%A6%E6%AE%8B%E3%81%97%E3%81%A6%E3%81%8A%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%81%99%E3%81%A7%E3%81%AB%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E4%B8%8A%E3%81%AE%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%A8%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%8C%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%82%E3%82%8B%E3%82%82%E3%81%AE%E3%81%A8%E6%83%B3%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
