8652 pinout orientation
1,226 次查看
petrus6432
Hi, I would like to be sure about MMA8652 mounting pinout. My sensor has a line and a "652 2YR" marking below.
Looking this, pin 1 is on the top left corner? Please refer to the attached image.
Thanks.
标记 (2)
1,100 次查看
TomasVaverka
Hi Pedro,
Yes, pin 1 is in the top left corner:
Square pad for pin 1, rounded pad for the other pins:
Tomas
PS: If my answer helps to solve your question, please mark it as "Correct" or “Helpful”. Thank you.
1,101 次查看
TomasVaverka
Hi Pedro,
Tomas
1,100 次查看
petrus6432
Thanks Tomas, one less thing to doubt.
