pkcs11-tool generates 2 private keys for keypairgen
user4
I'm expecting to have a public and a private key pair when I execute pkcs11-tool command with --keypairgen option, but the outputs says generated 2 private keys.
Is that an expected behavior of se050? If not, am I missing something important?
<Environment>
platform: Debian (bullseye)
module variant: SE050C1
<Outputs>
# pkcs11-tool --module $PKCS11_MODULE --keypairgen --key-type rsa:2048 --label "sss:20202020"
Using slot 0 with a present token (0x1)
smCom :WARN :Invalid conn_ctx
App   :INFO :Using PortName='/dev/i2c-1:0x48' (ENV: EX_SSS_BOOT_SSS_PORT=/dev/i2c-1:0x48)
sss   :INFO :atr (Len=35)
      00 A0 00 00    03 96 04 03    E8 00 FE 02    0B 03 E8 08
      01 00 00 00    00 64 00 00    0A 4A 43 4F    50 34 20 41
      54 50 4F
sss   :WARN :Communication channel is Plain.
sss   :WARN :!!!Not recommended for production use.!!!
Key pair generated:
Private Key Object; RSA
  label:      sss:20202020
  Usage:      decrypt, sign
  Access:     sensitive, always sensitive
  Allowed mechanisms: RSA-PKCS,SHA1-RSA-PKCS,SHA224-RSA-PKCS,SHA256-RSA-PKCS,SHA384-RSA-PKCS,SHA512-RSA-PKCS,RSA-PKCS-PSS,SHA1-RSA-PKCS-PSS,SHA224-RSA-PKCS-PSS,SHA256-RSA-PKCS-PSS,SHA384-RSA-PKCS-PSS,SHA512-RSA-PKCS-PSS,RSA-PP
  label:      sss:20202020
Kan_Li
Hi @user4 ,
Thanks for the information! I have tied the same with MW ver 4.5.1 , it just works as expected. Maybe you have to update the MW to the latest. Please kindly refer to the following for details.
Kan
Kan_Li
Hi @user4 ,
May I have the MW version?
Kan
user4
Hi Kan,
Thank you for responding.
Unfortunately, I don't know the specific version of MW because this environment was built by another company, but guessing it might be 4.2.0:
# dpkg -L plug-and-trust
/etc
/etc/plug-and-trust
/etc/plug-and-trust/openssl11_sss_se050.cnf
/usr
/usr/lib
/usr/lib/arm-linux-gnueabihf
/usr/lib/arm-linux-gnueabihf/engines-1.1
/usr/lib/arm-linux-gnueabihf/engines-1.1/e4sss.so
/usr/lib/arm-linux-gnueabihf/libsssapisw.so.4.2.0
/usr/lib/arm-linux-gnueabihf/plug-and-trust
/usr/lib/arm-linux-gnueabihf/plug-and-trust/libsss_pkcs11.so
/usr/share
/usr/share/doc
/usr/share/doc/plug-and-trust
/usr/share/doc/plug-and-trust/changelog.Debian.gz
/usr/share/doc/plug-and-trust/copyright
Kan_Li
Hi @user4 ,
Kan
user4
Hi Kan,
Thank you for the inputs. I've also verified that using the libraries in that version does solve the problem, so will consider to ask the package provider to update the MW.
%3CLINGO-SUB%20id%3D%22lingo-sub-1855553%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Epkcs11-tool%20generates%202%20private%20keys%20for%20keypairgen%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1855553%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI'm%20expecting%20to%20have%20a%20public%20and%20a%20private%20key%20pair%20when%20I%20execute%20pkcs11-tool%20command%20with%20--keypairgen%20option%2C%20but%20the%20outputs%20says%20generated%202%20private%20keys.%3C%2FP%3E%3CP%3EIs%20that%20an%20expected%20behavior%20of%20se050%3F%20If%20not%2C%20am%20I%20missing%20something%20important%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CENVIRONMENT%3E%3C%2FENVIRONMENT%3E%3C%2FP%3E%3CP%3Eplatform%3A%20Debian%20(bullseye)%3C%2FP%3E%3CP%3Emodule%20variant%3A%20SE050C1%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3COUTPUTS%3E%3C%2FOUTPUTS%3E%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%3E%23%20pkcs11-tool%20--module%20%24PKCS11_MODULE%20--keypairgen%20--key-type%20rsa%3A2048%20--label%20%22sss%3A20202020%22%0AUsing%20slot%200%20with%20a%20present%20token%20(0x1)%0AsmCom%20%3AWARN%20%3AInvalid%20conn_ctx%0AApp%20%20%20%3AINFO%20%3AUsing%20PortName%3D'%2Fdev%2Fi2c-1%3A0x48'%20(ENV%3A%20EX_SSS_BOOT_SSS_PORT%3D%2Fdev%2Fi2c-1%3A0x48)%0Asss%20%20%20%3AINFO%20%3Aatr%20(Len%3D35)%0A%20%20%20%20%20%2000%20A0%2000%2000%20%20%20%2003%2096%2004%2003%20%20%20%20E8%2000%20FE%2002%20%20%20%200B%2003%20E8%2008%20%0A%20%20%20%20%20%2001%2000%2000%2000%20%20%20%2000%2064%2000%2000%20%20%20%200A%204A%2043%204F%20%20%20%2050%2034%2020%2041%20%0A%20%20%20%20%20%2054%2050%204F%20%0Asss%20%20%20%3AWARN%20%3ACommunication%20channel%20is%20Plain.%0Asss%20%20%20%3AWARN%20%3A!!!Not%20recommended%20for%20production%20use.!!!%0AKey%20pair%20generated%3A%0APrivate%20Key%20Object%3B%20RSA%20%0A%20%20label%3A%20%20%20%20%20%20sss%3A20202020%0A%20%20ID%3A%20%20%20%20%20%20%20%20%2020202020%0A%20%20Usage%3A%20%20%20%20%20%20decrypt%2C%20sign%0A%20%20Access%3A%20%20%20%20%20sensitive%2C%20always%20sensitive%0A%20%20Allowed%20mechanisms%3A%20RSA-PKCS%2CSHA1-RSA-PKCS%2CSHA224-RSA-PKCS%2CSHA256-RSA-PKCS%2CSHA384-RSA-PKCS%2CSHA512-RSA-PKCS%2CRSA-PKCS-PSS%2CSHA1-RSA-PKCS-PSS%2CSHA224-RSA-PKCS-PSS%2CSHA256-RSA-PKCS-PSS%2CSHA384-RSA-PKCS-PSS%2CSHA512-RSA-PKCS-PSS%2CRSA-PP%0APrivate%20Key%20Object%3B%20RSA%20%0A%20%20label%3A%20%20%20%20%20%20sss%3A20202020%0A%20%20ID%3A%20%20%20%20%20%20%20%20%2020202020%0A%20%20Usage%3A%20%20%20%20%20%20decrypt%2C%20sign%0A%20%20Access%3A%20%20%20%20%20sensitive%2C%20always%20sensitive%0A%20%20Allowed%20mechanisms%3A%20RSA-PKCS%2CSHA1-RSA-PKCS%2CSHA224-RSA-PKCS%2CSHA256-RSA-PKCS%2CSHA384-RSA-PKCS%2CSHA512-RSA-PKCS%2CRSA-PKCS-PSS%2CSHA1-RSA-PKCS-PSS%2CSHA224-RSA-PKCS-PSS%2CSHA256-RSA-PKCS-PSS%2CSHA384-RSA-PKCS-PSS%2CSHA512-RSA-PKCS-PSS%2CRSA-PP%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1855553%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3ESE050%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1860031%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20pkcs11-tool%20generates%202%20private%20keys%20for%20keypairgen%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1860031%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Kan%2C%3C%2FP%3E%3CP%3EThank%20you%20for%20the%20inputs.%20I've%20also%20verified%20that%20using%20the%20libraries%20in%20that%20version%20does%20solve%20the%20problem%2C%20so%20will%20consider%20to%20ask%20the%20package%20provider%20to%20update%20the%20MW.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1859378%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20pkcs11-tool%20generates%202%20private%20keys%20for%20keypairgen%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1859378%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F232787%22%20target%3D%22_blank%22%3E%40user4%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EThanks%20for%20the%20information!%20I%20have%20tied%20the%20same%20with%20MW%20ver%204.5.1%20%2C%20it%20just%20works%20as%20expected.%20Maybe%20you%20have%20to%20update%20the%20MW%20to%20the%20latest.%20Please%20kindly%20refer%20to%20the%20following%20for%20details.%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Kan_Li_0-1714972873727.png%22%20style%3D%22width%3A%20539px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kan_Li_0-1714972873727.png%22%20style%3D%22width%3A%20539px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F277157i5E72F8A6E9A37C13%2Fimage-dimensions%2F539x248%3Fv%3Dv2%22%20width%3D%22539%22%20height%3D%22248%22%20role%3D%22button%22%20title%3D%22Kan_Li_0-1714972873727.png%22%20alt%3D%22Kan_Li_0-1714972873727.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EHave%20a%20great%20day%2C%3CBR%20%2F%3EKan%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3ENote%3A%3CBR%20%2F%3E-%20If%20this%20post%20answers%20your%20question%2C%20please%20click%20the%20%22Mark%20Correct%22%20button.%20Thank%20you!%3CBR%20%2F%3E-%20We%20are%20following%20threads%20for%207%20weeks%20after%20the%20last%20post%2C%20later%20replies%20are%20ignored%3CBR%20%2F%3EPlease%20open%20a%20new%20thread%20and%20refer%20to%20the%20closed%20one%2C%20if%20you%20have%20a%20related%20question%20at%20a%20later%20point%20in%20time.%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1857078%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20pkcs11-tool%20generates%202%20private%20keys%20for%20keypairgen%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1857078%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Kan%2C%3C%2FP%3E%3CP%3EThank%20you%20for%20responding.%3C%2FP%3E%3CP%3EUnfortunately%2C%20I%20don't%20know%20the%20specific%20version%20of%20MW%20because%20this%20environment%20was%20built%20by%20another%20company%2C%20but%20guessing%20it%20might%20be%204.2.0%3A%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%3E%23%20dpkg%20-L%20plug-and-trust%0A%2F.%0A%2Fetc%0A%2Fetc%2Fplug-and-trust%0A%2Fetc%2Fplug-and-trust%2Fopenssl11_sss_se050.cnf%0A%2Fusr%0A%2Fusr%2Flib%0A%2Fusr%2Flib%2Farm-linux-gnueabihf%0A%2Fusr%2Flib%2Farm-linux-gnueabihf%2Fengines-1.1%0A%2Fusr%2Flib%2Farm-linux-gnueabihf%2Fengines-1.1%2Fe4sss.so%0A%2Fusr%2Flib%2Farm-linux-gnueabihf%2Flibsssapisw.so.4.2.0%0A%2Fusr%2Flib%2Farm-linux-gnueabihf%2Fplug-and-trust%0A%2Fusr%2Flib%2Farm-linux-gnueabihf%2Fplug-and-trust%2Flibsss_pkcs11.so%0A%2Fusr%2Fshare%0A%2Fusr%2Fshare%2Fdoc%0A%2Fusr%2Fshare%2Fdoc%2Fplug-and-trust%0A%2Fusr%2Fshare%2Fdoc%2Fplug-and-trust%2Fchangelog.Debian.gz%0A%2Fusr%2Fshare%2Fdoc%2Fplug-and-trust%2Fcopyright%0A%2Fusr%2Flib%2Farm-linux-gnueabihf%2Flibsssapisw.so.4%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1856536%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20pkcs11-tool%20generates%202%20private%20keys%20for%20keypairgen%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1856536%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F232787%22%20target%3D%22_blank%22%3E%40user4%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EMay%20I%20have%20the%20MW%20version%3F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EHave%20a%20great%20day%2C%3CBR%20%2F%3EKan%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3ENote%3A%3CBR%20%2F%3E-%20If%20this%20post%20answers%20your%20question%2C%20please%20click%20the%20%22Mark%20Correct%22%20button.%20Thank%20you!%3CBR%20%2F%3E-%20We%20are%20following%20threads%20for%207%20weeks%20after%20the%20last%20post%2C%20later%20replies%20are%20ignored%3CBR%20%2F%3EPlease%20open%20a%20new%20thread%20and%20refer%20to%20the%20closed%20one%2C%20if%20you%20have%20a%20related%20question%20at%20a%20later%20point%20in%20time.%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E
