SE050: Failed to generate new ECC keypair
2,657 次查看
aleksei1
Hello. I'm trying to generate a ECC keypair (NIST-P256) on #SE050C. But I get an error
I've tried using ssscli
$ ssscli generate ecc 0x7777 NIST_P256
Generating ECC Key Pair at KeyID = 0x00007777, curvetype=NIST_P256
sss :INFO :atr (Len=35)
00 A0 00 00 03 96 04 03 E8 00 FE 02 0B 03 E8 08
01 00 00 00 00 64 00 00 0A 4A 43 4F 50 34 20 41
54 50 4F
sss :WARN :Communication channel is Plain.
sss :WARN :!!!Not recommended for production use.!!!
smCom :ERROR:PAL Read status error status = ff
smCom :ERROR:phNxpEseProto7816_GetRawFrame phNxpEse_read failed , status : 0xff
smCom :ERROR:phNxpEseProto7816_ProcessResponse phNxpEseProto7816_GetRawFrame failed starting recovery
sss :WARN :nxEnsure:'ret == SM_OK' failed. At Line:6884 Function:sss_se05x_TXn
sss :WARN :nxEnsure:'status == SM_OK' failed. At Line:3457 Function:sss_se05x_key_store_generate_key
ERROR:sss.keystore:sss_key_store_generate_key FAILED
ERROR! Could not generate ECC Key Pair at KeyID 0x00007777
I've augmented 'i2c_a7.c' to print I2C traffic and got the following (i2c messages in cursive):
i2c_read returned -1, errno: 5
i2c_write: (Len=5)
5A C0 00 FF FC
i2c_read: (Len=2)
A5 E0
i2c_read: (Len=1)
00
i2c_read: (Len=2)
3F 19
i2c_write: (Len=5)
5A C7 00 F7 B1
i2c_read: (Len=2)
A5 E7
i2c_read: (Len=1)
23
i2c_read: (Len=37)
54 50 4F 2A 8D
i2c_write: (Len=27)
5A 00 16 00 A4 04 00 10 A0 00 00 03 96 54 53 00
00 00 01 03 00 00 00 00 00 A8 C8
i2c_read: (Len=2)
A5 00
i2c_read: (Len=1)
09
i2c_read: (Len=11)
03 01 01 6F FF 01 0B 90 00 CC 8B
54 50 4F
i2c_write: (Len=16)
5A 40 0B 80 04 00 27 06 41 04 00 00 77 77 9C 01
i2c_read: (Len=2)
A5 40
i2c_read: (Len=1)
05
i2c_read: (Len=7)
41 01 02 90 00 B9 C0
i2c_write: (Len=10)
5A 00 05 80 02 0B 25 00 A0 48
i2c_read: (Len=2)
A5 00
i2c_read: (Len=1)
17
i2c_read: (Len=25)
41 82 00 11 01 01 02 01 01 01 01 01 01 01 01 01
01 01 01 01 01 90 00 34 77
i2c_write: (Len=16)
i2c_read: (Len=2)
A5 40
i2c_read: (Len=1)
05
i2c_read: (Len=7)
i2c_write: (Len=19)
5A 00 0E 80 81 61 00 09 41 04 00 00 77 77 42 01
03 5C 5E
.. 490 lines of the same error omitted ...
i2c_write: (Len=5)
5A 81 00 41 A3
i2c_read: (Len=2)
A5 82
i2c_read: (Len=1)
00
i2c_read: (Len=2)
DA 4F
i2c_write: (Len=19)
03 5C 5E
i2c_read: (Len=2)
A5 00
i2c_read: (Len=1)
02
i2c_read: (Len=4)
6D 00 72 63
i2c_write: (Len=5)
5A C5 00 47 82
i2c_read: (Len=2)
A5 E5
i2c_read: (Len=1)
00
i2c_read: (Len=2)
87 67
It looks like after sending the following command over I2C, SE050 stops responding on I2C bus.
5A 00 0E 80 81 61 00 09 41 04 00 00 77 77 42 01 03 5C 5E
The SE050 stops responding to reads from I2C.
标记 (2)
2,633 次查看
aleksei1
> are you using the latest MW?
I'm using v04.01.01 of MW. I think that is the latest to date.
The problem was that power supply for SE050 does not provide enough current during key generations and voltage drops below permissible levels.
@Kan_Li Thank you for the reply, please consider the issue resolved.
2,640 次查看
Kan_Li
Hi @aleksei1 ,
I tried to reproduce your issue here but no success, the ssscli commands work well from my side, are you using the latest MW? what is the dev kit on your hands? Did you modify the ssscli tool or use this tool out of box? Please kindly clarify.
Please have my result as below:
Kan
2,634 次查看
aleksei1
