Is it true that no need se50 if CAAM exists
brucezhao
IMX serial has SNVS and CAAM to encrypt user data, such as IoT credentials. I have two questions.
1. So I do not need an extra encryption chip such as se50, is it right?
2. SNVS will detect RTC,if a tamper event happend, SNVS will remove the key. So if I want to replate the cell battery of RTC, will SNVS remove the key? How SNVS knows it is under attack or in maintain mode?
Thank you.
