S32Z safety questions on WFI and FCCU interrupts in SAF
viktorfellinger
Dear support,
I’m discussing with Aptiv safety topics around S32Z
They have two questions where I would appreciate your support:
  1. Can you please have a look figure 270 in the below mail , if WFI is not received repeatedly what should be the recovery mechanism , it is told to be present in s
  2. afety manual. I don’t find any hit for WFI in safety manual.
  3. One question not from the topic of reset but for SAF. From Interrupt_map.xls(attachment in ref manual) can not find which one should be used for ‘alarm interrupt in FCCU’ for s32z. In S32 G its very clear from interrupt routing.xls.
Viktor
Tags (3)
