write in D-Flash (or P-flash) with IAP? (in application programming)
873件の閲覧回数
Ahmad_bozorgi
Hi.
in S32K14x series, there is flash module with 2 bank: P-Flash (Bank 0) and D-Flash (bank 1).
D-Flash can be FlexNVM for whole space or in a partition. assume I want to use FlexNVM with 32 KB from 64KB. so I have EEE with 4KB FlexRAM and back up space with 32 KB space.
the left 32KB partition is D-Flash now. can I write on this space individually ? (not write in FlexRAM & EEE unit).
literally I want to have some EEPROM emulated memory and some D-Flash memory with write access. (these procedures are not performed in same time).
Thanks.
861件の閲覧回数
lukaszadrapa
Hi Ahmad,
yes, that's possible. D-Flash which is not allocated for EEE can be used as a normal D-Flash using normal flash commands for program/erase.
Lukas
862件の閲覧回数
lukaszadrapa
Hi Ahmad,
Lukas
