value of constant variable not match the definition
BenjaminChen
Why the the values of a const struct  variable do not match with the definition?
and the variable "tslvEepConfig" in MAP file is like this
lukaszadrapa
Hi @BenjaminChen
isn't that just some kind of optimization? If you read the structure somewhere in your code, can you get correct values? Or did you receive just some garbage shown on your second screenshot?
Lukas
