hello,my s32ds for s32 can not view peripheral registers, I tried reinstalling it and sdk,But it doesn't work。
s32k312 svd file is existing.
this is my install software:
please help me ,thank you!
S32K31XEVB-Q100 S32DS-S32PLATFORM
Solved! Go to Solution.
Hi @xiaoyaojun,
Could you share your debug configuration?
Also, could you share how are you making the connection? I am assuming you are using a S32K312 EVB, are you debugging by OpenSDA or with an external debugger?
Please test firstly an example or an empty project with no configuration:
Julián
Hi @xiaoyaojun,
Julián
Thank you very much for reminding me, I found the reason! Because my SVD source file could not be found, the default path it used before was not found, I manually specified the path for him, and now my peripheral register can be displayed normally. the screenshot are my solution and I hope to help more people.
