uja1169 reset issue
uja1169 reset issue
2,287 次查看
949147417
Hello, I used S32K146 and UJA1169TK/F for Automotive project, after I programmed the S32K146 MCU, the first power cycle,our board can work normally, but in the next power cycle, SBC will reset MCU by 128ms period. MCU power supply is OK, why SBC reset MCU, watchdog is refreshed by SPI. Thanks, Can you help me?
标记 (1)
4 回复数
2,063 次查看
razva_tilimpea
Could you describe how do you use the power cycles?
Razvan
2,063 次查看
949147417
hello,after programmed the micro,remove JTAG
the first time power on the PCBA we build,sbc did not have reset issue,but the second power cycle SBC will Reset mcu
-Original-
2,063 次查看
razva_tilimpea
First time when SBC is delivered it is in FNMC (watchdog is disabled). Probably first time when you flash the board everything is fine because the time between switching from FNMC to normal mode and watchdog feed is small enough to avoid reset.
Next time when you power on the board the SBC will be in normal mode and it expects to be feed after 128ms from power on. Please be sure that first feed event occurs in time.
Razvan
2,063 次查看
949147417
great,we check the code and solve it,thanks
-Original-
