trying to revive a S32K148 board when its stuck in reset
Search instead for
SaiMacha
I’m currently trying to revive a board that is stuck in reset because I used strict sequential boot on it. I tried using the multilink’s emergency device recovery feature but it did not work. Is there anything else I can try to revive this board? Please advise.
danielmartynek
Hello @SaiMacha,
I'm afraid this is not possible.
Mass Erase is blocked by CSEc
(AN12130, 3.2.5.2 Mass erase and CSEc considerations, https://www.nxp.com/docs/en/application-note/AN12130.pdf)
You would need to use the DBG_CHAL / DBG_AUTH commands to remove the partitioning.
But this is not possible since the MCU is in reset.
