temperature sensor
temperature sensor
2,309 次查看
sambath_kumar_k
I am using S32k146. I see temperature sensor is supported in some places but in reference manual contains no information regarding the  temperature sensor to calculate the die temperature.
Can any one clarfiy
Does S32k146 has internal temperature sensor ? If so which ADC needs to be used to measure and what is the scaling factor for that ?
4 回复数
2,297 次查看
Robin_Shen
Hi sambath_kumar_k,
Sorry for the inconvenience we bring you!
I am afraid that the internal temp sensor module cannot be used yet.
Here is the feedback from internal team: We are working to add in the new revision of the RM the information about the internal temp sensor.
Robin
2,277 次查看
sambath_kumar_k
I am in middle of a project which needs this information. Can you provide details for S32k146:
  1. Which adc channel can read the internal temperature sensor ?
  2. What is the scaling factor ?
2,230 次查看
Robin_Shen
If you have NDA signed, I can share the preliminar documents to you through Support Tickets.
Robin
2,263 次查看
Robin_Shen
sorry for the long delay.
I am inquiring if I can share information to you before release.
