s32k3 recover hse
s32k3 recover hse
youxi
Hello:
I seem to have made some irregularities that caused the hse to shut down. I wrote this register once and then the hse fails.I wonder how to restore the hse now
VaneB
Hi @youxi
Could you provide me with the value you have in this register?
B.R.
VaneB
youxi
That's the register. I did not write in it successfully. Now if I read out the value of this register, it is still 0x40000000.
VaneB
Hi @youxi
Could you explain more about the behavior of the HSE and about how it does not work?
youxi
Hi @VaneB
I send a request to HSE for any service and cannot successfully get a response. But my HSE firmware has been successfully installed and has completed encryption and decryption before.
youxi
The value obtained here is 0.The same goes for using the right project
VaneB
Hi @youxi
As the HSEResponse is equal to no response is caused because HSE is not correctly installed.
To ensure that this is not your case, please verify if the HSE_FW Version (HSE_GetVersion_Example() matches the one installed, or check if the HSE FW usage flag is already enabled. These validations are made in the HSE demo app.
youxi
Hi @VaneB
Before this, HSE firmware was successfully installed, and can complete functions such as encryption and decryption. now. When I read the register, I read out the value. The value at position 0 is 0. The surface HSE is erased by SBAF
VaneB
Hi @youxi
By this you mean the definition of tr variable?
Could you provide more information?
youxi
Wait for a timeout, and you get this value
