s32k148evb ethernet pins
aurélien
I currently have the S32K148 EVB, and there is no access to the ethernet MII pins (excluding phy daughter board connector), do you have any idea about how I could connect my ethernet phy to it?
Thanks in advance.
PetrS
seems no other option is there, need to use phy daughter board connector you mentioned
BR, Petr
PetrS
BR, Petr
