s32k148 with lan8710a
rak14
Hello, I'm trying to integrate S32k148 with LAN8710a Phy. So, any insights or steps to be followed to configure this as I'm new to this.
Also any code related to the same would be helpful.
PetrS
there will not be direct guidance for this PHY. Maybe you can refer to https://www.nxp.com/part/S32K148EVB-KIT#/ and https://www.nxp.com/design/designs/s32k148-automotive-telematics-box-t-box-solution:S32K148-T-BOX
MCU is used there with TJA1101, 100BASE-T1 PHY Transceiver. MCU to PHY connection will be similar.
Some SDK examples are available within S32 Design Studio (enet_loopback, phy_tja1101, lwip).
BR, Petr
rak14
The hardware designed in such a way that PHY is connected to MAC (NXP S32K148) through MII mode.
But enet_loopback is in RMII mode any changes to be made other than changing from RMII mode to MII mode in ethernet configurator?
@PetrS can you tell me to pinging to work what are the steps to be followed?
