s32k144 is not working debug by opensda in s32k144 EVB
my head hurts so much
plz help me
why? i don't understand ~~plz help me plz plz
Hi hojun,
Would you please let me know the version of your S32K144EVB?(The schematic of several version for S32K144EVB are different.)
If board info(at bottom side) is SCH-29248 REV B1, connect Pin2-3 of J107. If board info is SCH-29248 REV C, connect Pin1-2 of J107.
J104 connect pin1-2
Using USB cable at J7 to debug and power S32K144EVB.
Select the Emgerency Kinetis Device Recovery by Full Chip Erase.
If this doesn't work, please try to use P&E Recovery Utility halt MCU by refer Recovering Cortex-M Microcontroller with a Power Glitch. After halt the MCU, you should be able to debug it.
Robin
