s32k144 CSEc CMD_ENC_ECB padding
Search instead for
In s32k144 CSEc CMD_ENC_ECB, how can I make input data padding in the application(the data length is not a multiple of 128-bit).
example)
data : 01 02 03 04 05(5Byte)
- S32K144 RM page 885
Is it a PKCS #7 padding or just add 0s?
you can use whatever you wish. It's up to you. Nice description can be found here, for example:
https://www.di-mgt.com.au/cryptopad.html
Lukas
Lukas
