s32k14 not connecting in open sda
Search instead for
soumilfm
Hello, My S32k148 EVB is not bieng able to debugged through opensda . 1. Already updated bootloader , pe micro drivers and open sda again . 2. red led near reset continuously RED 3. Have checked aleady with Kinetis erase option Nothing Seems to work . please Solutions outside the above three will be highly obliged. I am using windows 10 machine and tried freemaster as well as s32 design studio Regards
lukaszadrapa
if you check the reset signal by an oscilloscope, is it toggling after POR? Or is it tied to gnd all the time?
Do you have Seger J-Link or Lauterbach debugger? It could help if you can read out content of MDM-AP status and control register.
Lukas
