s32k复位引脚复位,与断电重启有何区别
Search instead for
78621251
  • s32k复位引脚复位,与断电重启有何区别? 我程序出现一次复位之后会不断复位,断电重启之后 就不会再复位了
78621251
what will cause   RCM_SRS_SW_MASK     (software) reset?
danielmartynek
Hi 78621251@qq.com,
This is a software reset.
https://community.nxp.com/message/1115254
78621251
Which registers can be cleared manually for non power-on reset so that they are the same as power-on reset status
danielmartynek
There is no list of registers that are cleared on POR only.
Each registers has its own specification.
For example:
danielmartynek
Hi 78621251@qq.com,
Some registers are reset only on power-on reset.
Could you read the RCM_SRS during startup to find the source of the reset?
BR, Daniel
78621251
RCM_SRS_PIN_MASK      this reason again and again
danielmartynek
Hi 78621251@qq.com,
If you see RCR_PIN = 1, that means that another device connected to the reset_b pin is the cause of the reset, not the MCU itself.
