s32ds s32k144 debug error
Search instead for
allennmk
There was no problem before.but yesterday  after generating processor expert code and building,my project elf file is missing.So i can't debug my project. And I use usb-opensda to debug
allennmk
if I add new component and generate  processor expert code,the elf file will miss after building.I load other project from Example,this problem will appear again.
dianabatrlova
Have you seen any error messages in the build console?
Maybe you have similar issue, please, check thread below:
I can not find my .elf & .map
I hope it helps.
Diana
