path variables in linked resource in s32 design studio for windows
2,589 次查看
sanjay645
Hello, i want to run a script that will create path variables in linked resources in s32 design studio.
Is there any possible way to do so, please help me out.
I want to create those path variables and paths using a script which i attached in the attachment here.
3 回复数
2,530 次查看
sanjay645
S32 DS do have linked resource, please see the image attached and let me know how can i make values of variables dynamic, for example, in the image, 'RTD_DIR_PATH' has value "C:\SVN\SW32K3_RTD_4.4_2.0.1" , I want that it should search the folder name starting with "SW32K3_RTD_" and put it in a variable and then use this variable to build the project in project paths.
2,483 次查看
VaneB
Hi @sanjay645
I am sorry for not giving me to understanding correctly.
It is possible to generate Linked resources with S32DS, as you said. I was referring to as far as we know it is not possible to use a script as you want.
As I mentioned before, our IDE is Eclipse-based, you can consult the following link. There should be information related to this topic which you might find useful.
Dynamic path variables
2,560 次查看
VaneB
Hi @sanjay645
As far as we know, S32DS does not have this feature for the linked resources. But as our IDE is Eclipse-based, you can consult the following link. There should be information related to this topic which you might find useful.
Eclipse documentation
B.R.
VaneB
