motor control with MCSPTE1AK344
Canberk
I have got MCSPTE1AK344 kit but I use it to run different motor with encoder. I used example code but directions can be wrong sometimes, I mean when I tried to turn the motor right it can be turn left.
How can I solve this
petervlna
Ok, and did you applied changes to application configuration for your motor?
I guess this is the issue here. Please set the application parameters for your motor accordingly.
Peter
