Hello. s32 team.
I want to use the example 'lpspi_transfer_s32k118'.(This example was updated in RTM3.0.0)
But I can not find how to connect a wire between master & slave.
Could you please let me know how to connect wire in 's32k118EBV_64'?
Thank you.
Best regards.
You can either check the PIN DRIVER configuration in the Design Studio
or refer to the SDK documentation in the SDK installation folder
...\S32DS_ARM_v2018.R1\S32DS\S32SDK_S32K1xx_RTM_3.0.0\doc\Start_here.html
BR, Daniel
