load key
591 次查看
youxi
Hi:
load key Is that what storing key in HSE means? The second time on, can these keys still be used to encrypt and decrypt?
标记 (1)
565 次查看
lukaszadrapa
Hi @youxi
yes, load key means that a key is either stored to flash or to RAM. Keys stored in flash will be available also after next reset / power cycle, RAM keys won't be available.
Format catalogue function will erase all the keys.
There's new set of HSE examples which could help:
https://www.nxp.com/webapp/Download?colCode=S32K3_HSE_DemoExamples
Lukas
583 次查看
youxi
In addition, if format key, will all keys be deleted?
566 次查看
lukaszadrapa
Hi @youxi
Lukas
