lib.a file creation using S32 SDK Project of s32k144.
Jeevansagar
I was just creating a library project in S32DS IDE and noticed that S32 SDK was not in the list, but all my projects were done using S32 SDK.
Can't we use S32 SDK in Library project?
If not, how can I create a lib.a file for my projects which are written using the S32 SDK?
Daniel-Aguirre
This seems to be related to the toolchain itself:
When you create a library project, you only select the family, not the product itself, as shown below:
When we create an application project, we select the product itself, as shown below:
Hence, we can attach an SDK to the application project, since the product is defined. Aside from this, there is not much telling about the library project restrictions. We do apologize.
Please, let us know.
