how to use the software reset method to reset the S32K116 MCU
Guofred
would you like to share the software reset sample code by using S32K116 MCU.
After the assignment as below method, use the Debug tool to observe that the value does not change, and the reset fails, would you like to share your comments. thanks.
Best regards.
davidtosenovjan
davidtosenovjan
Guofred
Hi @davidtosenovjan ,
Yes, thanks for your kindly help.
Best regards.
Guofred
