how to generate the negative voltage in SBC FS26
mogilipuri_harish
hello team,
can you tell me how to generate the negative 5V in SBC FS26
diazmarin09
Hello mogilipuri_harish,
I hope all is great with you. Thank you for using the NXP communities.
Unfortunately the FS26 device is not capable to generate negative voltage itself.
I hope this information helps.
David
