how to config Canoe being a Master to debug LIN
liuxing_hu
I want to use s32ds example project "lin_slave_s32k116" as Slave, Canoe being a Master to dubug LIN function based on s32k116EVB, but I don't know how to config Canoe project, could you give me some hints?
more notes and experience are welcomed
thanks you
liuxing_hu
but how debug between "lin_master" and "lin_slave" example? open 2 s32ds projects including "lin_master" and "lin_slave"? how to send and receive message at the same time?
PetrS
do not know CANoe, but what about to load ldf file from "lin_master" example. Thus you will know which messages should be sent.
BR, Petr
