flexio SPI loopback testing
4,137 次查看
ravihhk2
Hi, I'm testing SPI in flexio in s32k148 eval board. I have tested the initialization part (SPI Master configuration).
Can i do the loopback test without connecting the slave device to eval board to ensure my driver is working properly ??
or is there any other way to ensure that the transfer function is working? (I don't have scope/logic analyzer as of now)
Please help me.....
3,808 次查看
costinconstanti
As Daniel pointed out it is enough to connect MISO to MOSI. Just to add something of help maybe, of good use would be an oscilloscope that can decode SPI or better off a logic analyzer to be sure your board does what you expect it to do.
Good day,
Costin
3,808 次查看
danielmartynek
Hi ravihhk2@gmail.com,
You can simply connect MOSI - MISO pins.
The Master will receive whatever it sends.
BR, Daniel
3,808 次查看
ravihhk2
Thanks danielmartynek‌. I will try this. This will help for sure.
