cannot access memory on adress 0x40024090
已解决
跳至解决方案
928 次查看
12914A
I need to init FlexCAN0 and FlexCAN1. FlexCAN1 ist already working.
At the init of FlexCAN0 it stops after the 4th loop of clearing the RAMn[] message buffers.
It shows the WDOG_EWM_IRQ_Handler(). At the EmbSys Register overview it shows at RAMn[5] the error message: cannot access memory on adress 0x40024090.
What can I do to solve this problem?
Sandra
标记 (2)
1 解答
902 次查看
PetrS
if the module is clocked and enabled and you access valid address, which the MB area is, no fault is expected.
Hard to say, check above or share simplified project.
BR, Petr
在原帖中查看解决方案
1 回复
903 次查看
PetrS
BR, Petr
