can i get freertos example for s32k344?
rlaxortn
i could not find freertos example for s32k344.
my s32ds version 3.6 and rtd 4.0.0.
can i get example source and manual??
rlaxortn
@PetrS
i downloaded freertos.
i try to use freertos with example. but freertos does not work.
would you check this post?
https://community.nxp.com/t5/S32K/would-you-help-what-is-problem-for-using-freertos/m-p/2112705#M497...
thanks for help.
PetrS
in that thread you pointed to FreeRTOS compatible with RTD500, as Daniel wrote.
You need to use right version based on your RTD installed.
BR, Petr
PetrS
download and install desired FreeRTOS package based on your RTD installed
https://www.nxp.com/webapp/swlicensing/sso/downloadSoftware.sp?catid=SW32K3-REFSW-D
Read release note document to be sure of right steps for package installation.
BR, Petr
