adjust memory allocation of int_sram for S32K312
已解决
跳至解决方案
551 次查看
f-nelson
Hi NXP:
we're developing project by default linker script(linker_flash_s32k312.ld),but we encountered overflow problem at int_sram section. I'd like to adjust sram section (reduce int_sram_shareable and extented int_sram ), Could you tell me what is mean about int_sram_shareable section? int_sram_shareable looks like no use in current project application.
default memory allocation:(linker_flash_s32k312.ld)
MEMORY
int_pflash : ORIGIN = 0x00440000, LENGTH = 0x0007F800 /* 511KB */
int_pflash_custom : ORIGIN = 0x004BF800, LENGTH = 0x00000400 /* 1KB */
int_dflash : ORIGIN = 0x10000000, LENGTH = 0x00020000 /* 128KB */
int_itcm : ORIGIN = 0x00000000, LENGTH = 0x00008000 /* 32KB */
int_dtcm : ORIGIN = 0x20000000, LENGTH = 0x0000F000 /* 60KB */
int_stack_dtcm : ORIGIN = 0x2000F000, LENGTH = 0x00001000 /* 4KB */
int_sram : ORIGIN = 0x20400000, LENGTH = 0x00007F00 /* 32KB , needs to include int_sram_fls_rsv*/
int_sram_fls_rsv : ORIGIN = 0x20407F00, LENGTH = 0x00000100
int_sram_no_cacheable : ORIGIN = 0x20408000, LENGTH = 0x00007F00 /* 32KB , needs to include int_sram_results */
int_sram_results : ORIGIN = 0x2040FF00, LENGTH = 0x00000100
int_sram_shareable : ORIGIN = 0x20410000, LENGTH = 0x00008000 /* 32KB */
ram_rsvd2 : ORIGIN = 0x20418000, LENGTH = 0 /* End of SRAM */
current project memory usage:
Memory region Used Size Region Size %age Used
int_pflash: 221156 B 510 KB 42.35%
int_pflash_custom: 40 B 1 KB 3.91%
int_dflash: 0 GB 128 KB 0.00%
int_itcm: 0 GB 32 KB 0.00%
int_dtcm: 1032 B 60 KB 1.68%
int_stack_dtcm: 0 GB 4 KB 0.00%
int_sram: 32328 B 32512 B 99.43%
int_sram_fls_rsv: 0 GB 256 B 0.00%
int_sram_no_cacheable: 16332 B 32512 B 50.23%
int_sram_results: 256 B 256 B 100.00%
int_sram_shareable: 0 GB 32 KB 0.00%
ram_rsvd2: 0 GB 0 GB
current environment description:
MCU:S32K312/100pin
S32DS Product:3.5.0.202207261815
RTD S32KXX:RTD5.0.0.202410011049(installed RTD5.0.0_P8)
HSE firmware:HSE_FW_S32K312_0_2_55_0
1 解答
498 次查看
davidtosenovjan
Following code/data sections are supposed to be assigned into int_sram_shareable:
“. mcal_shared_data”: MCAL data section--global variables belonging to MCAL with initial value expected to be shared with multicore.
“. mcal_shared_bss”: MCAL bss/common section--global variables belonging to MCAL with zero or no initial value expected to be shared with multicore.
在原帖中查看解决方案
2 回复数
447 次查看
f-nelson
Hi davidtosenovjan:
many thanks. Now we didn't use AutoSAR components for developing, so I will change size between int_sram and int_sram_shareable.
499 次查看
davidtosenovjan
%3CLINGO-SUB%20id%3D%22lingo-sub-2136840%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E8%B0%83%E6%95%B4%20S32K312%20%E7%9A%84%20int_sram%20%E5%86%85%E5%AD%98%E5%88%86%E9%85%8D%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2136840%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%E6%81%A9%E6%99%BA%E6%B5%A6%EF%BC%9A%3CBR%20%2F%3E%EF%BC%8C%E6%88%91%E4%BB%AC%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%E9%BB%98%E8%AE%A4%E7%9A%84%E9%93%BE%E6%8E%A5%E5%99%A8%E8%84%9A%E6%9C%AC%EF%BC%88linker_flash_s32k312.ld%EF%BC%89%E5%BC%80%E5%8F%91%E9%A1%B9%E7%9B%AE%EF%BC%8C%E4%BD%86%E5%9C%A8%E5%BC%80%E5%8F%91%E8%BF%87%E7%A8%8B%E4%B8%AD%E5%87%BA%E7%8E%B0%E4%BA%86%E4%B8%80%E4%BA%9B%E9%97%AE%E9%A2%98%E3%80%82%E6%88%91%E4%BB%AC%E5%9C%A8%3CSTRONG%3Eint_sram%3C%2FSTRONG%3E%E9%83%A8%E5%88%86%E9%81%87%E5%88%B0%E4%BA%86%E6%BA%A2%E5%87%BA%E9%97%AE%E9%A2%98%E3%80%82%E6%88%91%E6%83%B3%E8%B0%83%E6%95%B4%20sram%20%E9%83%A8%E5%88%86%EF%BC%88%E5%87%8F%E5%B0%91%3CSTRONG%3Eint_sram_shareable%3C%2FSTRONG%3E%E5%92%8C%E6%89%A9%E5%B1%95%3CSTRONG%3Eint%3C%2FSTRONG%3E_sram%EF%BC%89%EF%BC%8C%E6%82%A8%E8%83%BD%E5%91%8A%E8%AF%89%E6%88%91%20int_sram_shareable%20%E9%83%A8%E5%88%86%E6%98%AF%E4%BB%80%E4%B9%88%E6%84%8F%E6%80%9D%E5%90%97%EF%BC%9Fint_sram_shareable%20%E5%9C%A8%E5%BD%93%E5%89%8D%E9%A1%B9%E7%9B%AE%E5%BA%94%E7%94%A8%E4%B8%AD%E4%BC%BC%E4%B9%8E%E6%B2%A1%E6%9C%89%E7%94%A8%E5%A4%84%E3%80%82%3C%2FP%3E%3CP%3E%E9%BB%98%E8%AE%A4%E5%86%85%E5%AD%98%E5%88%86%E9%85%8D%EF%BC%9A%EF%BC%88linker_flash_s32k312.ld%EF%BC%89%3CBR%20%2F%3EMEMORY%3CBR%20%2F%3E%7B%3CBR%20%2F%3Eint_pflash%20%3A%20ORIGIN%20%3D%200x00440000%2C%20LENGTH%20%3D%200x0007F800%20%2F*%20511KB%20*%2F%3CBR%20%2F%3Eint_pflash_custom%20%3A%20ORIGIN%20%3D%200x004BF800%2C%20LENGTH%20%3D%200x00000400%20%2F*%201KB%20*%2F%3CBR%20%2F%3Eint_dflash%20%3A%20ORIGIN%20%3D%200x10000000%2C%20LENGTH%20%3D%200x00020000%20%2F*%20128KB%20*%2F%3CBR%20%2F%3Eint_itcm%20%EF%BC%9AORIGIN%20%3D%200x00000000%2C%20LENGTH%20%3D%200x00008000%20%2F*%2032KB%20*%2F%3CBR%20%2F%3Eint_dtcm%20%3A%20ORIGIN%20%3D%200x20000000%2C%20LENGTH%20%3D%200x0000F000%20%2F*%2060KB%20*%2F%3CBR%20%2F%3Eint_stack_dtcm%20%3A%20ORIGIN%20%3D%200x2000F000%2C%20LENGTH%20%3D%200x00001000%20%2F*%204KB%20*%2F%3CBR%20%2F%3Eint_sram%20%EF%BC%9AORIGIN%20%3D%200x20400000%2C%20LENGTH%20%3D%200x00007F00%20%2F*%2032KB%2C%20%E9%9C%80%E8%A6%81%E5%8C%85%E5%90%AB%20int_sram_fls_rsv*%2F%3CBR%20%2F%3Eint_sram_fls_rsv%20%3A%20ORIGIN%20%3D%200x20407F00%2C%20LENGTH%20%3D%200x00000100%3CBR%20%2F%3Eint_sram_no_cacheable%20%3A%20ORIGIN%20%3D%200x20408000%2C%20LENGTH%20%3D%200x00007F00%20%2F*%2032KB%2C%20%E9%9C%80%E8%A6%81%E5%8C%85%E5%90%AB%20int_sram_results%20*%2F%3CBR%20%2F%3Eint_sram_results%20%EF%BC%9AORIGIN%20%3D%200x2040FF00%2C%20LENGTH%20%3D%200x00000100%3CBR%20%2F%3Eint_sram_shareable%20%3A%20ORIGIN%20%3D%200x20410000%2C%20LENGTH%20%3D%200x00008000%20%2F*%2032KB%20*%2F%3CBR%20%2F%3Eram_rsvd2%20%3A%20ORIGIN%20%3D%200x20418000%2C%20LENGTH%20%3D%200%20%2F*%20SRAM%20%E7%BB%93%E6%9D%9F%20*%2F%3CBR%20%2F%3E%7D%3C%2FP%3E%3CP%3E%E5%BD%93%E5%89%8D%E9%A1%B9%E7%9B%AE%E5%86%85%E5%AD%98%E4%BD%BF%E7%94%A8%E6%83%85%E5%86%B5%EF%BC%9A%3CBR%20%2F%3E%E5%86%85%E5%AD%98%E5%8C%BA%E5%9F%9F%20%E5%B7%B2%E7%94%A8%E5%A4%A7%E5%B0%8F%20%E5%8C%BA%E5%9F%9F%E5%A4%A7%E5%B0%8F%25%E5%B7%B2%E7%94%A8%E5%B9%B4%E9%BE%84%3CBR%20%2F%3Eint_pflash%3A%20221156%20B%20510%20KB%2042.35%25%3CBR%20%2F%3E%20int_pflash_custom%EF%BC%9A40%20B%201%20KB%203.91%25%3CBR%20%2F%3E%20int_dflash%3A%200%20GB%20128%20KB%200.00%25%3CBR%20%2F%3E%20int_itcm%3A%200%20GB%2032%20KB%200.00%25%3CBR%20%2F%3E%20int_dtcm%3A%201032%20B%2060%20KB%201.68%25%3CBR%20%2F%3E%20int_stack_dtcm%3A%200%20GB%204%20KB%200.00%25%3CBR%20%2F%3E%20int_sram%EF%BC%9A32328%20B%2032512%20B%2099.43%25%3CBR%20%2F%3E%20int_sram_fls_rsv%3A%200%20GB%20256%20B%200.00%25%3CBR%20%2F%3E%20int_sram_noo_cacheable%EF%BC%9A16332%20B%2032512%20B%2050.23%25%3CBR%20%2F%3E%20int_sram_results%3A%20256%20B%20256%20B%20100.00%25%3CBR%20%2F%3E%20int_sram_shareable%EF%BC%9A0%20GB%2032%20KB%200.00%25%3CBR%20%2F%3E%20ram_rsvd2%3A%200%20GB%200%20GB%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E5%BD%93%E5%89%8D%E7%8E%AF%E5%A2%83%E6%8F%8F%E8%BF%B0%EF%BC%9A%3CBR%20%2F%3EMCU%3AS32K312%2F100pin%3CBR%20%2F%3ES32DS%20Product%3A3.5.0.202207261815%3CBR%20%2F%3ERTD%20S32KXX%3ARTD5.0.0.202410011049(installedRTD5.0.0_P8)%3CBR%20%2F%3EHSE%20firmware%3AHSE_FW_S32K312_0_2_55_0%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2140422%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20adjust%20memory%20allocation%20of%20int_sram%20for%20S32K312%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2140422%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F52613%22%20target%3D%22_self%22%3E%3CSPAN%20class%3D%22%22%3Edavidtosenovjan%3C%2FSPAN%3E%3C%2FA%3E%3A%3C%2FP%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E3%80%82%3CSPAN%3E%E7%8E%B0%E5%9C%A8%E6%88%91%E4%BB%AC%E6%B2%A1%E6%9C%89%E4%BD%BF%E7%94%A8%20AutoSAR%20%E5%85%83%E5%99%A8%E4%BB%B6%E8%BF%9B%E8%A1%8C%E5%BC%80%E5%8F%91%EF%BC%8C%E6%89%80%E4%BB%A5%E6%88%91%E5%B0%86%E5%9C%A8%20int_sram%20%E5%92%8C%20int_sram_shareable%20%E4%B9%8B%E9%97%B4%E6%9B%B4%E6%94%B9%E5%A4%A7%E5%B0%8F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2137359%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20adjust%20memory%20allocation%20of%20int_sram%20for%20S32K312%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2137359%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E4%BB%A3%E7%A0%81%2F%E6%95%B0%E6%8D%AE%E9%83%A8%E5%88%86%E5%BA%94%E5%88%86%E9%85%8D%E5%88%B0%20int_sram_shareable%EF%BC%9A%3CBR%20%2F%3E%22.mcal_shared_data%22%EF%BC%9AMCAL%20%E6%95%B0%E6%8D%AE%E9%83%A8%E5%88%86--%E5%B1%9E%E4%BA%8E%20MCAL%20%E7%9A%84%E5%85%A8%E5%B1%80%E5%8F%98%E9%87%8F%EF%BC%8C%E5%85%B6%E5%88%9D%E5%A7%8B%E5%80%BC%E5%BA%94%E4%B8%8E%E5%A4%9A%E6%A0%B8%E5%85%B1%E4%BA%AB%E3%80%82%3CBR%20%2F%3E%22.mcal_shared_bss%22%EF%BC%9AMCAL%20bss%2Fcommon%20%E9%83%A8%E5%88%86--%E5%B1%9E%E4%BA%8E%20MCAL%20%E7%9A%84%E5%85%A8%E5%B1%80%E5%8F%98%E9%87%8F%EF%BC%8C%E5%85%B6%E5%88%9D%E5%A7%8B%E5%80%BC%E4%B8%BA%E9%9B%B6%E6%88%96%E6%97%A0%E5%88%9D%E5%A7%8B%E5%80%BC%EF%BC%8C%E9%A2%84%E8%AE%A1%E4%B8%8E%E5%A4%9A%E6%A0%B8%E5%85%B1%E4%BA%AB%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
