account issue_cannot show HSE FW over 2024
SploreLcp
Found my account cannot show HSE FW over 2024, see below,
What can I do?
lukaszadrapa
Hi @SploreLcp
Please check it now, it has been solved, you should already see all the versions.
Lukas
lukaszadrapa
Hi @SploreLcp
Well, I can see also version 0.2.55.0 from February 2025. I will check it with responsible team.
Could you just confirm if the problem is related to your account changping.liu@avnet.com ?  Or is that a problem of your customer? If so, please share the email. Thank you.
Lukas
SploreLcp
Yes, related to my account.
lukaszadrapa
Hi @SploreLcp
Lukas
SploreLcp
Hi, Lukas,
Yes, checked & solved.
Thanks!
