Which initialization should be done again after sCheck
已解决
跳至解决方案
1,657 次查看
jhuang1
Hi, I found Platform_Init() has to be called again after sCheck on s32k312, or the intm may not work. I think sCheck may change some settings on checking and leave it unchanged back. Should I recall all the initialize function to reset the periphrals? Such as Mcu_Init(), Mcl_Init(),Rm_Init().
1 解答
1,627 次查看
danielmartynek
Hi @jhuang1,
Which sCheck do you mean?
Refer to S32K3_SAF_SCHECK_UM.pdf
sCheck start-up
"The start-up tests override a configuration of the tested hardware modules. Configuration changes applied to the tested hardware modules may not be restored to their defaults at the end of start-up testing, therefore the user application is supposed to reconfigure the hardware modules before they can be used for user application purpose."
sCheck runtime
"These tests run with present hardware configuration of the tested module (if applicable) and always restore configuration of the tested hardware modules to the state which they have been in before the testing started."
在原帖中查看解决方案
1 回复
1,628 次查看
danielmartynek
Hi @jhuang1,
sCheck start-up
sCheck runtime
%3CLINGO-SUB%20id%3D%22lingo-sub-1883324%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EsCheck%20%E4%B9%8B%E5%90%8E%E9%9C%80%E8%A6%81%E5%86%8D%E6%AC%A1%E8%BF%9B%E8%A1%8C%E5%93%AA%E4%BA%9B%E5%88%9D%E5%A7%8B%E5%8C%96%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1883324%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E6%88%91%E5%8F%91%E7%8E%B0%E5%9C%A8%20s32k312%20%E4%B8%8A%E6%89%A7%E8%A1%8C%20sCheck%20%E4%B9%8B%E5%90%8E%E5%BF%85%E9%A1%BB%E5%86%8D%E6%AC%A1%E8%B0%83%E7%94%A8%20Platform_Init()%EF%BC%8C%E5%90%A6%E5%88%99%20intm%20%E5%8F%AF%E8%83%BD%E6%97%A0%E6%B3%95%E5%B7%A5%E4%BD%9C%E3%80%82%E6%88%91%E8%AE%A4%E4%B8%BA%20sCheck%20%E5%8F%AF%E8%83%BD%E4%BC%9A%E6%9B%B4%E6%94%B9%E6%A3%80%E6%9F%A5%E7%9A%84%E4%B8%80%E4%BA%9B%E8%AE%BE%E7%BD%AE%E5%B9%B6%E4%BF%9D%E6%8C%81%E4%B8%8D%E5%8F%98%E3%80%82%E6%88%91%E6%98%AF%E5%90%A6%E5%BA%94%E8%AF%A5%E8%B0%83%E7%94%A8%E6%89%80%E6%9C%89%E5%88%9D%E5%A7%8B%E5%8C%96%E5%87%BD%E6%95%B0%E6%9D%A5%E9%87%8D%E7%BD%AE%E5%A4%96%E5%9B%B4%E8%AE%BE%E5%A4%87%EF%BC%9F%E5%A6%82Mcu_Init()%E3%80%81Mcl_Init()%E3%80%81Rm_Init()%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
