Where we can find Chip configuration information
2,255件の閲覧回数
gkunalupta
Where can we find the chip configuration information for NXP S32K1xx Microcontrollers
2,101件の閲覧回数
Senlent
Hi@gkunalupta
PDB is an internal module of the chip, and it has no external pins connected to it directly.
PDB needs to be connected to external pins through the TRGMUX module.
In the previous answer, I have told you the location of S32K1xx_Trigger_Muxing.xlsx
6 返答(返信)
2,181件の閲覧回数
Senlent
Hi@gkunalupta
Could you describe your problem in more detail?
Do you want the datasheet for s32k1 or something else?
2,248件の閲覧回数
gkunalupta
Also from where can i found information on which pin to use for pulse-out?
タグ(1)
2,170件の閲覧回数
gkunalupta
I want to know where can i finds chip specific details, for trigger inputs details which are mentioned:
I want to know about trigger inputs, for that on datasheet it is written that find information on chip configuration details. Where can i find that???
2,165件の閲覧回数
Senlent
Hi@gkunalupta
S32K1xx_Trigger_Muxing.xlsx can be found in S32K-RM's attachments.
2,119件の閲覧回数
gkunalupta
And where can i find information for device chip configuration details  to know about PDB Pulse out pin
2,102件の閲覧回数
Senlent
Hi@gkunalupta
