What should be the value of seed and generator polynomial?
Search instead for
beingalpha18
I am using CRC module of S32K142, But I am not able to understand what should be the value of seed and generator polynomial for real CRC calculation on data.
Robin_Shen
Hi Mr Alpha,
You can read: Understanding and implementing CRC (Cyclic Redundancy Check) calculation
seed also calls initial value
Hope it helps!
Robin
kef2
Senior Contributor IV
Seed and poly depends on CRC type. This routine works for 16 bits CRC-CCITT (0x1021 poly):
unsigned int crc16(const void* buf, size_t len)
char oddlen;
union{
   unsigned char *c;
   unsigned short *s;
   unsigned long *l;
}ptr;
               PCC->PCCn[PCC_CRC_INDEX] |=PCC_PCCn_CGC_MASK;
    CRC->CTRL |= CRC_CTRL_TCRC_MASK;
    CRC->GPOLY = 0x10210000;          // poly <<16
    CRC->CTRL |= CRC_CTRL_WAS_MASK;
    CRC->DATAu.DATA = 0x0;
    CRC->CTRL &= ~CRC_CTRL_WAS_MASK;
    ptr.l = (void*)buf;
    oddlen = len & 3;
    len /= 4u;
    while(len--)
               CRC->DATAu.DATA = __builtin_bswap32(*ptr.l++);;
    while(oddlen--)
               CRC->DATAu.DATA_8.LL = *ptr.c++;
    return CRC->DATAu.DATA_16.H;
Edward
