I accidentally burned the S32K142 chip code into the S32K146, resulting in the chip memory lock, how to solve
Solved! Go to Solution.
Then there is nothing I can do, this should be permanently locked
I don't know why the flashing is successful, because usually the debugger will check the part number of the device when flashing.
First of all, I need to tell you that this may not 100% percentage return to normal.
You can try to read the MDM-AP register to evaluate the current state of the chip.
Please read the following document carefully, which can help you understand the cause of the chip lock
I open the document,but it shows wrong content,maybe you gave me the wrong file?
Can you provide a screenshot? What is the value of your MDM-AP?
After clicking yes to confirm the execution of mass erase, is it prompted that the unlocking is successful?
