What is the S32K312 P-flash & D-flash P/E cycle?
StephenYeh
We found S32K3xxDS.pdf said that flash memory with 1MB or 2MB blocks ONLY has 1000 P/E cycles.
We also found that S32K312 not only has P-Flash (program flash : 2MB) but also have D-Flash (data flash : 128KB).
So, could you help to confirm following information ?
Q1 : Does S32K312 P-Flash only has 1000 P/E cycles ?
Q2 : How many P/E cycles that S32K312 D-Flash have ?  Is 100K cycles or still only have 1000 cycles ?
davidtosenovjan
Hi, flash memory on this device consist of 2x1MB blocks (code flash) and 1x256kB block (data flash).
1) 1MB blocks has endurance at least 1,000 P/E cycles.
2) 256kB block has endurance at least 100,000 P/E cycles.
