Hello :
Recently, while testing the upgrade program, a failure occurred when erasing the P-Flash. I suspect that the address selected for erasure is not aligned with the sector. I would like to confirm the sector sizes of S32K146 and S32K142. Besides initializing the Flash and not being able to erase the P-Flash, are there any other restrictions when erasing the P-Flash?
Solved! Go to Solution.
please refer to this article which you can find all answer you want related to S32K-Flash
