WDOG Window mode in S32K146
Shruthi_C
In S32K146 Microcontroller WDOG module, if we operate in window mode what should be the range of window value with respect to timeout value
If timeout value is 500 what can i put the range of Window value
Please support
Robin_Shen
The WIN register determines the earliest time that a refresh sequence is considered valid. The WIN register value must be less than the TOVAL register value.
I don't see a particular limitation other than the above.
23.3.1.5 Watchdog Window Register (WIN).jpg23.4.2 Watchdog refresh mechanism.jpg
Robin
Shruthi_C
Hi Robin
Only requirement is WIN value should be less than TVOL value right. There is no specific range for WIN value.
Thanks for your support
