VR5510 configuration via I2C
784件の閲覧回数
Kazarian
Is there a library where we it demonstarted how to configure the PMIC VR5510 during each startup ?
i could not find such sequence/flowshart in Datasheet.
VR5510 should be set into Normal mode, and Watchdog should be refreshed each X ms otherwise a reset should occur.
i know there is a sw package called  [TestApp_FRDMK82F] that uses FreeRTOS,it is fine but we are not using any OS for this bringup.
Thank you.
772件の閲覧回数
Daniel-Aguirre
VR5510 is commonly paired with S32G microprocessor, for which the available drivers for VR5510 should be provided under the S32G RTD packages.
Aside from this, we don't see any information on regards of VR5510 being paired with the FRDMK82F.
If you need more information on regards of VR5510 bring-up, help us opening a ticket under the NXP online services, for the dedicated team to provide a better support.
We apologize for any inconvenience.
Please, let us know.
