User push buttons in S32K3x4
ishoboiM
Hello, I need to know whether I can Turn the led on whenever I click the user button (USER_SW0) provided in the Microcontroller via S32 Design studio. I have tried implementing Projects from examples (Pit_Gpt_Ip namely) and changing the code from there, have met with only errors and a roadblock, If possible can you help me with
1.  Any project that defines or uses the user buttons as hands on experience
2. How the user button works, how to use it in projects or in S32
PetrS
refer to attached very simple example based on Port_ip demo in rtd500
hope it helps.
BR, Petr
